G37x (AWD) Coil-overs redux
This is an AWD version adapted from Slartibartfast's RWD thread. I've quoted some of his considerations below as I think they are a valuable. Obviously there are FAR fewer options available for AWD applications, but I did my best to cover as much as I could find. If you have answers to blank areas feel free to message me and I will update (or ADMINs just add it in). I haven't quite zero'd in on how to appropriately estimate front/rear frequency ratio based on spring rates as Slarti has or how spring location (OEM vs. True) affects estimating that since that has (or should) impact rear spring rate.
AWD Coilover Specifications
Brand: BC
Model: BR Series
P/N: V-08-BR
Price: $995 ($1350 w/Swift Springs)
Type: OEM
Body type: Monotube
Upper mount: Pillowball or Rubber
Separate hgt adjust [1]: Yes
Damping type: Linear
Damping adjust (F/R): 30/30
Rate (F/R), kg/mm:10k/8k
Front/rear ratio [2 ]:
Spring diameter, mm[3]:
Rebuildable: Yes
Warranty (yr): 1 year Limited
Note: Springs customizable and upgradable to Swift
Brand: Broadway Static
Model: 500s
P/N:
Price: $1399
Type: OEM Style
Body type: Monotube
Upper mount: Rubber
Damping type: Digressive
Damping adjust (F/R): 24/24
Rate (F/R), kg/mm: Custom
Rebuildable: Yes
Warranty (yr): 5 year
Note: Custom built off Fortune Auto base. Can upgrade to Swift Springs.
Model: Version II
P/N:
Price: $1999
Type: OEM Style OR True
Body type: Monotube
Rate (F/R), kg/mm: Custom - Recommended 14k/10k
Rebuildable: Yes
Note: Custom hand built to spec, can add on Swift Springs, Helper Springs, Remote Damper Control & Air Piston Lift.
Brand: D2 Racing
Model: RS Series
P/N: D-IN-10
Price: $975
Type: True
Body type: Monotube
Damping type:
Damping adjust (F/R): 36/36
Rate (F/R), kg/mm:
Rebuildable:
Note:
Brand: Feal
Model: 441
P/N: 441NI-15
Price: $1285
Type: True
Body type: Monotube
Rate (F/R), kg/mm: 12k/5k
Rebuildable: Yes
Note: Feal spring rate not customizable
Model: 441+
P/N: 441NI-15+
Price: $1549
Type: True
Body type: Monotube
Rate (F/R), kg/mm: customizable Swift springs
Rebuildable: Yes
Note:
Brand: Fortune Auto
Model: 500 Series
P/N: FA500-G37x
Price: $1330 ($1680 Swift Springs)
Type: OEM
Body type: Monotube
Upper mount:
Rate (F/R), kg/mm: 11k/8k
Spring diameter, mm[3]: 60mm
Rebuildable: Yes
Warranty (yr): 5 year Limited
Note: Upgradable to Swift or Hyperco Springs - Also Canister upgradable to 2-way or 3-way.
Brand: Godspeed
Model: MonoMax
P/N: MMX-3590
Price: $840
Type: OEM
Body type: Monotube
Damping type:
Damping adjust (F/R): 40/40
Rate (F/R), kg/mm: 14k/8k
Spring diameter, mm[3]: 62mm
Rebuildable:
Note:
Brand: KSport
Model: Kontrol Pro
P/N: CIN021-CP
Price: $850
Type: True
Body type: Monotube
Damping type:
Rate (F/R), kg/mm: 16k/8.7k
Rebuildable: Yes
Note:
Brand: Megan Racing
Model: EZ II Series
P/N: MR-CDK-IG09AW-EZII
Price: $750
Type: OEM
Body type: Monotube
Upper mount: Rubber
Damping type:
Damping adjust (F/R): 15/15
Rate (F/R), kg/mm: 10k/8k
Rebuildable:
Note:
Brand: Scale
Model: Innovative Series
P/N: IF11-IS
Price: $1245
Type: True
Body type: Monotube
Damping type:
Damping adjust (F/R): 12/12
Rebuildable: Yes
Warranty (yr): 2 year
Note: Many custom options (e.g. spring rates [$0], spring colors [$165] , stainless components [$45], 2-way external adjusters [$1000], swift springs [$350], pillow ball upper mounts [$100], low [$0] & extreme low [$100], lock ring collar color [$35])
Brand: Silver’s
Model: Neomax
P/N: NN143
Price: $1095
Type: True
Body type: Monotube
Upper mount:
Rebuildable:
Warranty (yr): 18 month
Note: Customizable spring rates
Brand: Stance
Model: XR-1
P/N: ST-V35-XR1
Price: $1350
Type: True
Body type: Monotube
Damping adjust (F/R): 16/16
Rate (F/R), kg/mm: 12k/8k
Rebuildable: Yes
Note: Listed for the G35 AWD but seems to be adaptable to our platform.
Brand: TruHart
Model: Street Plus
P/N: TH-1803
Price: ≈$600
Type: True
Body type: Twintube
Upper mount: Solid Aluminum
Damping adjust (F/R): Non-Adjustable
Rebuildable: Yes
Note: Sister company to D2 - dampening setting modeled after D2’s average settings.
Brand: YellowSpeed
Model: Dynamic ProSport
P/N: YS01-IN-DPS016
Price: $979.00
Type: True
Body type: Twintube
Upper mount: Aluminum w/Hardened Rubber Bushings
Damping adjust (F/R): 33-way
Rate (F/R), kg/mm: 12k/7k
Rebuildable: Not stated
Warranty (yr): Not stated
Note: Built to order
Slartibartfast:
[1]Separate height adjustment is better. Without it, changing spring perch height affects spring preload and damper rod position in the shock body, potentially taking it out of normal damping range.
[2] Front/rear frequency ratio should not be 1:1 as this promotes a hobbyhorse effect when hitting bumps. Don’t have frequency data so have to infer from spring rates.
[3] Spring diameter is helpful if you wish to change spring rates.
[4] Aluminum bodies to reduce weight. Half this weight is sprung, the other half unsprung.
[5] Heaviest part of shock is attached to vehicle instead of hub. Unsprung weight is the same for calculation purposes but mass accelerated over bumps is lower.
1 kg/mm = 55.8 lb/in
Brand: BC
Model: BR Series
P/N: V-08-BR
Type: OEM
Body type: Monotube
Rebuildable: Yes
Model: 500s
P/N:
Price: $1399
Type: OEM Style
Body type: Monotube
Upper mount: Rubber
Rebuildable: Yes
Model: Version II
P/N:
Price: $1999
Body type: Monotube
Rebuildable: Yes
Brand: D2 Racing
Model: RS Series
P/N: D-IN-10
Price: $975
Type: True
Body type: Monotube
Damping type:
Rate (F/R), kg/mm:
Rebuildable:
Note:
Brand: Feal
Model: 441
P/N: 441NI-15
Price: $1285
Type: True
Body type: Monotube
Rebuildable: Yes
Model: 441+
P/N: 441NI-15+
Price: $1549
Type: True
Body type: Monotube
Rebuildable: Yes
Note:
Brand: Fortune Auto
Model: 500 Series
P/N: FA500-G37x
Type: OEM
Body type: Monotube
Upper mount:
Rebuildable: Yes
Brand: Godspeed
Model: MonoMax
P/N: MMX-3590
Price: $840
Type: OEM
Body type: Monotube
Damping type:
Rebuildable:
Note:
Brand: KSport
Model: Kontrol Pro
P/N: CIN021-CP
Price: $850
Type: True
Body type: Monotube
Damping type:
Rebuildable: Yes
Note:
Brand: Megan Racing
Model: EZ II Series
Price: $750
Type: OEM
Body type: Monotube
Upper mount: Rubber
Damping type:
Rebuildable:
Note:
Brand: Scale
P/N: IF11-IS
Price: $1245
Type: True
Body type: Monotube
Damping type:
Rebuildable: Yes
Brand: Silver’s
Model: Neomax
P/N: NN143
Price: $1095
Type: True
Body type: Monotube
Upper mount:
Rebuildable:
Brand: Stance
Model: XR-1
P/N: ST-V35-XR1
Price: $1350
Type: True
Body type: Monotube
Rebuildable: Yes
Brand: TruHart
Model: Street Plus
P/N: TH-1803
Price: ≈$600
Type: True
Body type: Twintube
Rebuildable: Yes
Brand: YellowSpeed
P/N: YS01-IN-DPS016
Price: $979.00
Type: True
Body type: Twintube
The following 10 users liked this post by KidJai06:
Armani97 (09-21-2019),
Baadnewsburr (07-10-2018),
BigSpoon (10-24-2021),
blnewt (07-10-2018),
EcstaticG37XS (07-12-2018),
and 5 others liked this post.
No problem. I updated it with general prices. Add-ons or customization will obviously add to the overall costs. I'm sure in many cases reaching out to vendors on this site can be more specific and perhaps even provide a better rate.
Yes you're right about the rear dampers being short, here is the link to where this is discussed in another thread: https://www.myg37.com/forums/brakes-...options-9.html
I feel like coilovers were listed for our platform as direct fit when Stance had the SS coilovers but with the update to XR its not exact but still workable as long as one is communicating what is needed from Stance.
The following 3 users liked this post by KidJai06:
Slowg37x (07-12-2018)
I appreciate the sticky...hopefully it's helpful.
KidJai06 (07-13-2018)
The following 2 users liked this post by KidJai06:
Baadnewsburr (07-13-2018),
G37XS13 (07-12-2018)
I remember perusing their website previously, looked like they put out a pretty nice product. I will shoot them an email to see what they might be able to offer for AWD.
Thanks for the update, I never heard of a number of those options even after readign so many threads on here...for the Truehart ones I found this info:
The TruHart StreetPlus Coilover system is a full monotube design coilover with integrated aluminum top mounts. The StreetPlus coilover is an ideal solution for today's budget-minded tuner looking to lower their vehicle and increase handling performance. The independently adjustable lower mount allows fine tuning of a vehicle's height without sacrificing shock travel, resulting in a sporty yet comfortable ride on the street or strip. These coilovers do not have damper adjustments.
Fitment:
Twin Tube Shock Design
Separate Pre-Load Spring
Adjustable mount for ride height adjustment
Powder Coated shock bodies & Anodized Lock Rings for durability
Top-Hats or Camber Top-Plates included where applicable
Fitment:
Infiniti G37X 06-13
https://www.vividracing.com/truhart-...151801369.html
Fitment:
Fitment:
Infiniti G37X 06-13
Yeah much of the same was listed on their website also. Unfortunately they didn't list much of the information I wanted to know (i.e. coilover type, spring rates, amount of adjustment, etc.). It didnt give me a lot of confidence in their product but for sake of being thorough I included it in the list. I did actually send an email to Truhart asking for more info, if they respond I'll update it here.
From Brandon at TruHart (I also updated the initial post to reflect details discussed):
The I803 coilovers convert the rear to a one piece coilover, the picture on our website is the actual coilovers for your vehicle. The top mounts are solid aluminum mounts. All of our streetplus coilovers use linear dampening which is nonadjustable. We used our sister company’s, D2 racing, coilover’s average settings and set up our streetplus dampening to that dampening since most people find a dampening setting they like and then never adjust it again. Streetplus coilovers are only ride height adjustable they do not have dampening adjustiblity. Ride height can be adjusted roughly from 1.25in-3.5in from stock ride height on average for the streetplus line. The coilovers are rebuildable in the sense that we sell all the parts to repair the coilovers, and replacement shocks are $70each. The spring rates for the I803 are 16K front 8.7K rear.
Thanks!
Thanks!
I agree. The front rates in most applications seem a little high to me. I intend to take some measurements and attempt some calculations once I get home from vacation and see if I can come up with a reasonable idea as to what spring rates may be most appropriate (in conjunction with properly setup dampers). I'd like to achieve flat ride with rear frequency being approx. 20-25% higher than the front. I have Hotchkis F&R sway bars, both allow some adjustability. I also still have my OEM bars stored away in the event the need would arise to soften further. I've been intrigued by the idea that bigger/stiffer stabilizer bars may give a stronger feeling of control while actually reducing grip insomuch as it reduces the independence of the suspension.
