Vdc and slip light on
hey I have a 2009 g37 stock and it has the vdc and slip light on. I changed the brakes because it needed it and even topped of the brake fluid but the light is still there ? Any ideas what could be throwing the light ??
so when I start up the car the vdc and slip light is not on, but if I turn my steering wheel completely to the left it comes right on? Any suggestion what it can be ? Maybe faulty sensor ? Thank you
All it takes something small to get between the pad and caliper to throw it off. Also you might have damaged the caliper piston when you compressed them to get out old pads.
the light has been there even before I changed the brakes so I don’t think it’s the calipers. But sometimes before vdc and slip light comes on and I’m about to pull out of my driveway and turn right my car does like a drag noise from the drivers side brakes. Kind of like if the brake is stuck with the rotor or something is stuck and I just keep going then it stops and vdc light and slip will stay illuminated. Any ideas ?
Initial B
05-13-2018 10:51 PM
Marcasummers
12
07-23-2017 05:28 PM
