best Lowering springs
Looking for the overall best lowering springs for the sedan. I want to keep a similar ride quality and not have to change out the struts unless needed. I've done some research but can't decide between Swift sport springs , H&R sport springs or Eibach springs. I want to hear yall's opinions on these springs and which one would overall be the best. Thanks for the help!
Swift
Front 1.2
Rear .8
H&R
Front 1.3
Rear 1.2
Eibach
Front 1.5
Rear 1.2
These are the sedan numbers. Not to worried about the amount of drop but which one has the best ride quality and handling.
Also my car only has 20k miles so I will probably keep the shocks.
Front 1.2
Rear .8
H&R
Front 1.3
Rear 1.2
Eibach
Front 1.5
Rear 1.2
for RWD, maybe consider cheap coilovers like the Tiens too, thay arent that much more than springs and the shocks will last much longer given they are designed for them and coils tend to give a better ride than a mix of lowering springs and stock shocks. Also the install is easier on coil overs that come preassembled for the fronts.
And there's probably a reason why a complete coilover setup isn't much more than just springs
I wouldn't go by the drop data for the H&Rs, they are a deep drop spring in the 2" range unless they've truly gone to a different spring from the ones I've seen. They are a deeper drop than Tein S Techs which are pretty deep too. You would need full F&R camber kits w/ those sets to keep your tires wearing well.
I think you're right about the tophats though...I think they're the only coilovers I've seen that do that
you can also check the classified on for used coilovers. They come up pretty regularly but sell quickly so check often.
good luck
Lances Infiniti (06-19-2018)
Is that for the Sedan though? I know the coupe has a further drop than the sedans.
