Tanabe nf210 springs & H&R spacers.
Got just my shipment for both today. Should be installed by the weekend 🤘 update soon.
Still debating on leaving the rear springs stock .. As I really just wanted to get rid of that horrible front gap. 15 rear 20 front
Tanabe is a mild drop but to get your toe and your camber in spec you will almost surely need the rear kit. If you don't get the kit the alignment tech can get toe in spec (which is more critical for tread wear) but will have to run excess camber to get the toe proper. A little extra camber shouldn't be too bad regarding wear but YMMV.
Just dropped my car off to get front only springs installed. I'll post a pic in this thread when I get it back to help out your decision. Will also see how good they are able to get the alignment without a camber kit.
Itskoopa (03-14-2018)
Here it is fresh from the shop. Not the best pics, need to get it cleaned up and on a perfectly level surface but it came out great. I did front only because I measured the the ground to fender height stock and it was exactly an inch higher in the front. Looks even now with just the front dropped.
Drives the same as stock from the 3 miles I’ve driven. Need some more seat time but I’m very happy so far
04gtoryder (03-16-2018)
Wanted to leave the rear springs stock.. But I talked myself into just doing it all the way around.. Though I do love the stock rear and tanabe front look. Hoping it settles a little more in the front after a few days. Overall I'm happy with the way it came out.
20mm spacers in the front..
15mm rears.
I'll take better pictures when I get a chance too.
Cheers
15mm rears.
Cheers
blnewt (03-18-2018)
