Good rotors
Young, Dumb and Stung
Good rotors
Hello I'm going to be buying a 2011 infiniti g37xs and it needs new rear rotors. What rotors are best for the G37? Going to be doing a lot to this car want to get only the best!!
thank you
thank you
Centric premium rotors are a good choice, have better venting than OEM and rust reduction coating. These can be found on rockauto.com or cross check the part #s on Amazon and w/ their free shipping you may get a better deal there. Be sure to choose 320mm front, 307mm rear rotor sizes.
If your rear rotors are bad more than likely your fronts will probably be needed too unless they were already replaced. If the fronts are fine then just getting the Centric premium rears is ok, and Akebono ProAct pads are a good choice for pads, Stoptech has a newer Street pad that performs well and won't dust much vs. their Sport pad, those should also be found at rockauto.
Ideally getting a full front & rear setup w/ matching pads all around is best, but if you want to do just the rear be sure to match the fronts when it's time.
I'm going to be getting the car this weekend New (to me) and I got it inspected by Infiniti the rotors and the battery was the only problem allowed me to get a good deal so I'll probably just do them all to be better safe then sorry and for the long run
FelipeRueda
11-15-2016 05:58 PM
q60scash
10-26-2016 01:18 AM
