X sedan - Ideal height setup on C/O's?
19" rims 245/40 275/35 tires
I'm going in for a coilover setup tomorrow. What's the ultimate target stance for an X sedan? I read a comment that 26 3/4" was great for 19" wheels. But my biggest question is how to achieve a level setup without the reported 1/2" rear droop? Any suggestions greatly appreciated!:driving: |
26.75" is a good target to allow you to navigate easily on a daily basis and to keep that transfer case (and y-pipe, exhaust tips) from getting too low to the obstacles you might face. Luckily coilovers don't settle as drastic as lowering springs so you can set it much closer to your settled height from day one.
That rear sag that occurs w/ some lowering springs is something that typically occurs after the initial settling, not something that gets more drastic over time. Luckily it's only a couple brands that are doing this. If you set your coilovers at 26 7/8" you should get that 26.75 as they won't settle much, or 27" just to be safe. You acn set the rears about 1/8" higher if you want to insure a slightly raked look vs being lower in back. Luckily readjusting the height isn't too involved, maybe you can ask the installer if you can come back in a week in case the height isn't exactly where you want and see what they say, wouldn't hurt to ask. |
(Post 4131812)
That rear sag that occurs w/ some lowering springs is something that typically occurs after the initial settling, not something that gets more drastic over time. Luckily it's only a couple brands that are doing this. If you set your coilovers at 26 7/8" you should get that 26.75 as they won't settle much, or 27" just to be safe. You acn set the rears about 1/8" higher if you want to insure a slightly raked look vs being lower in back. Luckily readjusting the height isn't too involved, maybe you can ask the installer if you can come back in a week in case the height isn't exactly where you want and see what they say, wouldn't hurt to ask. What's the best F/R target to attempt to get an even stance w/o the droop, regardless of the drop? Ideally I'm leaning towards 26.5" FTG |
Not to high jack the thread from Coltrane1.
What would be the benefit of having the rear slightly higher than the front? Thanks!
(Post 4131812)
I'm at zero gap w/ my RWD and it's 26.25" to the fender arcs w/ 26.7" diameter tires.
I've been very happy w/ this setup vs. when I was 25.75", much more cringe-worthy situations then. With that AWD system to consider I think 26.75 would be a good plan, and if it settles to 26.5 should still be able to deal with it, and the great thing about coilovers is you can reevaluate at any time. And if you just change your height a 1/4" your alignment should still be in spec if you have it set w/ some room at the edges. G37xS life~A little higher in back is a better stance than being higher in front, so if you set it just a hair higher it's not a bad look. |
Originally Posted by G37xS-Life
(Post 4131814)
What would be the benefit of having the rear slightly higher than the front? Thanks! |
(Post 4131948)
Generally, rear springs are softer than the front so the rear has to be taller to handle max load and keep relative height with front. It can also add a bit more oversteer than a level stance. Some do this to provide clearance for tires that are too wide for the wheel well.
1 Attachment(s)
So glad you got that rear shock situation remedied and hopefully brought enough attention to the problem that it won't happen to another member around here.
That height is definitely looking proper! |
(Post 4133129)
Car looks super fresh!
| All times are GMT -4. The time now is 12:25 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
