New Akebono BBK on the cheap!
#106
#107
Do the calipers from discountinfinitiparts.com come painted oem silver or are they unfinished? I'm confused after all the talk on this thread about painting & powdercoating...
#110
https://www.myg37.com/forums/brakes-...templates.html
JUMBO PALACE (06-21-2016)
#116
FYI for anyone buying centric brake hardware kit for the Akebonos. The pins that comes with the rear kit are the same length as the fronts. That will cause them to poke out the rear calipers; As opposed to being flush. You will either need to cut them to be flush, or buy the OEM rear pins at substantially more. Cheapest I've seen is $6.16 per pin.
#117
So looks like I have a problem and my pass rear caliper is leaking. I'm thinking rebuild as a first measure. I know there's DIYs for this but I rather take it somewhere.
Where have others gotten this work done? General mechanic? Brake shop? How much can I expect to pay(ballpark)?
#118
More Information for CENTRIC 14342039
Have to call around and get quotes, a independent brake shop would be a good first place to call, but should be a straightforward DIY if you don't mind getting a bit dirty lol.
Your calipers are almost new aren't they? check your bleed screws and brake line mounts first.
#119
Check rockauto.com, here's the part #, and this is for a single rear caliper
Since having the calipers installed...everything was fine until I noticed my brake light coming on under accel. I checked and yup my fluid level had dropped. I topped it off and it happened again slowly. So I had Infiniti check while they did my 60K and they confirmed that I am leaking brake fluid and the pass rear caliper looks to be leaking...so my thought is rebuild and hope that fixes it. If not then I guess new caliper, but hopefully not.
There's quite a few small shops near me, even within walking distance. So I guess I'll get quotes in the AM and hopefully drop the car off right then.
ugggh
#120
Hopefully it's just a seal, not uncommon, especially w/ a used caliper. If you have a corroded piston causing it not to seal then it will be a bit more, but still not too much $$ as long as there's no damage to the piston bore in the caliper.
More than likely it's a simple fix.
G37xhibeet (08-18-2016)
