G37X coilover options - Page 2 - MyG37
Notices
Old 03-07-2014, 04:44 PM
Modr8r & DIY cheapsk8
Originally Posted by CRV_33 View Post
AMR Engineering is another option. I personally I havent had any experience with them but I know you can specifiy the spring rate. Its all made to order and it comes with a lifetime warranty.
AMR Engineering | Providing you peace of mind.
They're an option but the reason they're not listed is because they've started out here w/ extremely disappointing customer service, check this thread for a taste of what's been going on
https://www.myg37.com/forums/brakes-...rs-review.html
blnewt is offline
The Following User Says Thank You to blnewt For This Useful Post:
CRV_33 (03-07-2014)
Old 03-07-2014, 05:08 PM
CRV_33
Wow thanks for bringing the thread listed above to my attention.
Again thank you for making this coilover thread dedicated to the X drivetrain owners.
CRV_33 is offline
Old 03-07-2014, 05:30 PM
iPwnN00bz4F1
If you don't lower the car much you may get by w/out the camber kits but a typical 1.25" or greater drop and you should invest in them. Those camber plates they talk about aren't applicable to our front suspension setup, just a generic description of their coilover line.
Well that WAS a big selling point haha. But I'm still planning on getting them. I'll just play it safe with the dropping at first. I hear it's mainly the rear that requires a camber kit, does that mean I could have a more aggressive drop in the front without worries? like 1.6"
I believe the eibach springs lower the fronts by 1.9".
I feel like I just asked what you said, I guess I just wanted to confirm if that 1.25" was all around. Thanks!
iPwnN00bz4F1 is offline
Old 03-07-2014, 07:34 PM
tbulsara
i am running the D2 racing coil overs..
right now the top of my wheel well is 26" from the ground.
i like the D2 because you get the dampening settings as well.
i had to run a camber kit as well.
ride is a little rough but then again im running a 10.5 wheel all around with 275/30/20 tires.
Attached Thumbnails G37X coilover options-tbp_4271-1-.jpg   G37X coilover options-d2-racing.jpg
tbulsara is offline
Old 03-07-2014, 09:16 PM
Eibachs should only drop around 1.3" but YMMV
With coilovers you could drop it mild, get your alignment and basically just drop it enough to have alignment that you can live with. I still recommend getting the whole F&R kit but that's just my 2 cents. The front toe is adjustable so regardless of your camber you can still get toe in spec, but the front camber isn't adjustable from the factory so w/out the front arms you'll have camber out if you drop more than 1.25" give or take. The rear camber & toe only has minimal factory adjustment so to get the toe in spec you at least need the rear toe bolt kit unless you really keep the drop subtle.
blnewt is offline
Coltrane1 (04-29-2017)
Old 03-07-2014, 09:19 PM
Your G is looking nice w/ those wheels and the drop. You really should add a detailed review of those coils since we're trying to get a good database for other X owners. Possibly some pics of the coils and ease of adjustment, any noise issues and what height range the coils have (if you can give a rough estimate) All this kind of info will really help this thread to become a valuable resource. Appreciate any help you can provide, and again, nice G you're putting together
Brad
blnewt is offline
Old 03-08-2014, 10:15 AM
tbulsara
Unfortunately, i dont have any pictures of the coil overs, installed them the same day they came is as i was excited to get them in.
as far the the Height, i can still go about 2-3 inches lower, so the height range on the D2 are great, but you also have to keep in mind, that you dont want to go too low, as you will strain the front drive arms ( they will be at a weird angle causing vibrations)
The D2 is fairly easy to adjust the height even after installation.
One thing to keep in mind, is that if you want to adjust the dampening, the front can be done after installation, but the rear you have to do before installation, as the trunk area is all sealed for better noise dampening.
HMU if you guys have any questions.
tbulsara is offline
Old 04-21-2014, 05:25 PM
m0nster
m0nster's Avatar
K-Sport Review
Well here's my review of the K-Sport Kontrol Pro Coilovers;
Part Number: CIN021-KP
Spring rates: 16k front, 8.7k rear
Here they are in the box, love at first sight
Opened up and on the floor
I installed them in about 8 hours taking my time. It was my first time installing coils on a car I really cared about so it was a little bit nerve racking.
Installation of the fronts went perfectly fine. Everything lined up properly and I had no trouble adjusting them.
The rears on the other hand were missing a nut. The nut that secures the rear shock to the lower shock mount is welded on to the OEM shock. To my disappointment, the K-Sport kit did not supply this nut. Thankfully I had access to another car and there is a brafasco close by. I had to buy two nuts ( 12X1.25 ) and use them for installation. Mind you, they only cost about $2 but I was just a little upset they didn't come with my $1200(CAD) coilover kit. I never contacted K-Sport about this issue but I will be sure to do so.
After installation was complete and I adjusted the height and dampening to where I wanted, I must say I couldn't be happier. I set the front and rear 26" from fender to floor and dampening around -14 from hardest in front and rear.
I had a couple people in the car and they had no complaints whatsoever.
There are absolutely NO NOISES coming from anywhere. The ride is amazing. There's lots of room for adjustment (around 2" down and 2"+ up).
All in all, I would definitely recommend this kit to anyone who is looking to drop their X. It's amazingly quiet, comfortable and easy to use.
I've only driven about 5-600km on them so far, but if they keep going the way they are, you won't be hearing any complaints from me
Edit - Sorry for the iPhone4 pics lol
m0nster is offline
The Following 3 Users Say Thank You to m0nster For This Useful Post:
lorentzoe45 (07-02-2017), yonith (09-25-2016), _GH0ST_ (01-18-2015)
Old 04-26-2014, 11:35 AM
Don't know how I missed this review. Thanks a bunch for posting the good pics and info. Please post updates if you have any issues (or just want to back up your praises) and any more pics. Nice to have some info coming in for the X guys wanting more choices.
blnewt is offline
Old 05-21-2014, 04:49 PM
MylilG
Very nice. I think I might have to rethink my options. So confusing on what to go with. Would like to get more feedback on the Fortune 500's. K-Sports do look nice though.
MylilG is offline
Old 11-29-2014, 01:12 PM
fengyink
Nice sticky post.
Tanabe has their sustec TSC130 with all other model noted as 2WD except 09+ G37 Sedan (no note, suspect 08 G35 sedan also belong to this category with same platform). I suspect they forgot to add the note. Sent an email and waiting for reply. Will update once received a reply. Do not think will get any until next week.
If any fellow received negative / positive already, please post back. Thank you.
If you guys know of any additional coilover systems for the AWD X models please post them here w/ part #s. Do not post pricing from a vendor though. A price range is OK but not specific vendor pricing. Thanks!
Here's the latest review of the newest coilovers from Fortune 500, they look promising!
https://www.myg37.com/forums/brakes-...er-review.html
Here's one I just found out about today so have no idea on the quality or overall value, any feedback is appreciated on any of these coil setups
FWIW All of these coilover sets are in the under $1000 range
Ksport Adjustable Coilover Systems, Camber Kits and Suspension Products | Ksport Store
Another one that's been added
D2 Coilovers
D-IN-10 RS Coilovers
RS Series - D2 Racing - High Performance Suspension & Brakes
And the older standbys~
Megan Racing Street LP series~
Megan Racing
BC Racing Part#V-08
http://www.bcracing-na.com/2013BCRac...cationList.pdf
fengyink is offline
Old 01-18-2015, 06:18 PM
_GH0ST_
I know this is a old post, but did you ever manage to take photos of how the rear is set up, being that we have separate springs from the shock?...
Thanks
_GH0ST_ is offline
Old 02-04-2015, 09:35 PM
m0nster
m0nster's Avatar
Sorry i dont have any pics of how its set up. Its basically just the coilover mounted where the oem strut goes and no spring in the bucket. I haven't had any issues with them at all and the roads around me are HORRIBLE. I have them set at max stiff on the dampening and they still don't ride that bad.
I can't comment on how the coilover style affects handling since i'm not really setup for track or anything. If you're looking for a decently priced coilover that rides comfortable, these are the ones for you.
Thanks
m0nster is offline
Old 02-09-2015, 03:36 PM
  #29
ai3j50
Do any of the coilover options for the X offer a setting that is near stock ride height? I have an X coupe on Eibachs and I would consider coils if I could raise the ride up higher during the winter.
ai3j50 is offline
The Following User Says Thank You to ai3j50 For This Useful Post:
Mindows7 (02-10-2015)
Old 02-22-2015, 10:06 AM
  #30
G37xhibeet
Can we revive this thread. I'm looking to drop as soon as winter is over and I'd like to not spend much money. I was actually considering the Eibach Pro Kit but reportedly the ride is too harsh???. So right now I'm considering KSport or Megan as the Fortune options is just too expensive.
G37xhibeet is offline
Quick Reply: G37X coilover options
Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
