Looking for advice on brake/rotor replacement + 60K maint.
I tried to avoid the forums initially and tried to do research to figure all of this out, but I bit the bullet. Forums have always been helpful in the past so here goes.
I have an 09 Infiniti G37X w/ 50K miles on it (7/AT).
1 - When I apply the brakes I can feel pulsating in the brakes so I am assuming the rotors are warped. I am thinking replaced front and rear pads and rotors and get it out of the way.
I was wondering if this would be a good option?
http://www.summitracing.com/parts/pwr-k114/overview/
I figured it was a pretty descent price all the way around. I am assuming that the calipers do not need replaced?
I found a few places that will put everything on for $150. I can probably do it myself, but I am really limited on time, so I figured pay someone and be done with it.
Are there any other brakes/rotors you would recommend? Not trying to spend a ton.
2 - I have been having some issues with what seems to be my transmission.
Example: When I am at a stop light and accelerating slowly around the corner, then continue to drive straight and maintain speeds around 30 MPH, the transmission wants to stay in a higher gear and maintain 1K RPM. It is bogged down. I experience jerkiness when the car downshifts also. If I throw my car in N, sometimes I will get an PM spike, say at 1,500.
There are 2 occasions that I can think of that I was driving, and my RPMs spiked significantly to like 4K RPM. No idea what happened, but it eventually fixed itself.
So I think something is going on. I took it to the dealer twice now, and they keep resetting the ECU saying that it will learn how I drive. I do not drive conservative for the most part. I live in the DC area so there is a lot of stop and go.
I just feel as though my car is not driving as it should. It often times wants to stay at 1K RPM and drive boggy until I give it a lot of gas then it will pick up. The transmission is just not smooth. The car still has pick up, don't get me wrong.
Not sure what to do next. Any ideas? I am going to try to take it back to the dealership again I guess. I have a 100K warranty..
3 - My 60K maintenance is coming up. What is necessary, and what is fluff (i.e. a money maker for the dealership). I am assuming the belts need looked at replaced, but what about all of the fluids? What can be done DIY? I am an ok with cars, I can change oil and troubleshoot basic stuff with youtube, etc.
Any help is appreciated! I just don't want to get taken at the dealership, and would like to ensure I buy some good brakes/rotors which probably need replaced soon. Also no idea what is going on with my transmission and wondering if it is something else?
-Shawn
-Shawn
I cringe a little whenever I read someone who writes about "warped rotors". At 50K miles, you should be totally fine. Have the rotors resurfaced, and take it to a mechanic who will properly bed-in the new pads to the rotors.
HAWK makes a quality replacement pad that's better than OEM without breaking the bank. You can buy them from TireRack, both Ceramics and HPS. Or any auto store, for that matter. I've tried both on a previous car, and preferred the HPS for completely subjective and unproveable reasons.
I bought my k114 set from rock auto for roughly $20 cheaper. They look and perform great, very happy with the decision. Make sure to flush your break system with whatever you choose.
RockAuto Mobile Catalog
^This.
So take off the rotors and take them to a machine shop with new brake pads?
How long will a resurfacing last? If it will last a good while I guess that is the way to go.
-Shawn
Non sport rotors are crap and do warp as early as 50k, resurfacing is only going to make them warp at a faster rate. My rotors are shot at 50k and I have a journey sedan, I do not drive my car hard at all and abuse the brakes. I'm sure the guys talking of rotors not warping at 50k are sport owners with the Akebono brakes, the rotors for that setup are far superior to the Non sport rotors.
Performance Aftermarket and OEM Parts for the 300ZX 350Z G35 G37 240SX Skyline GT-R Nissan Peformance lineup
Akebono Infiniti G35 / G37 F & R 14 Inch Big Brake Kit w/ Stoptech Rotors, 07+ Sed, 08+ Cpe
Part#: G37-41000-AKI03G37
Drilled
Drilled
stealth210
General Tech Questions
27
07-26-2017 06:48 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
