Help understanding coilovers!
Alright guys, so I recently got my 2010 G37. Got some nice wheels, and lowered on H&R Springs, then the mod bug hit me. I wanna go lower already. BUT, I've never had a lowered car before and need help with coilovers. I was looking into getting BC BR coil overs, any experiences with them? Also, what exactly is a camber kit, and will I be needing one? Thanks guys!
BC coils are a well known brand, but like any coilover.. sometimes u hit a miss and can get faulty ones. ones you lower your car you will by default get negative camber and your toe will be off, you have a few options here. 1. tell the place you get your alignment u want your toe in spec, with this at least you wont kill the tires within a month but you will still be riding negative camber and option 2 is buying a camber kit and having the shop align it to spec so your toe and camber will be close if not at factory settings (depends how low you go)
oh, be careful with speed bumps and if u are double guessing if u can make it... dont lol! |
Lol It'll probably be safer to go with a camber kit. Just more money to spend! It's lowered just a bit right now, and I do wanna go a bit lower. Tired of having a tire gap!
From what I hear, anything lower than an inch you will have to do more modification to the suspension like camber, sway bar and etc. Ive been thinking about dropping my car lower myself, but got damn speed bumps >_<
I'm a bit surprised you have much gap at all w/ the H&Rs, they're usually pretty slammed. Those are typically springs that you definitely need camber/toe kits. Going lower is no problem w/ coils, my rears already drop 1.5" at the "highest" setting and will drop all the way until the tires are resting on the inner fender liners :)
The fronts can go much higher (like a 4x4 w/ 4" of gap) and still go slammed. Be careful going much lower than what H&Rs drop, those stainless exhaust sleeves, front bumper lip, and rear lower exhaust tips really take a beating (along w/ your spine). For sure the camber/toe kits is a good investment for anyone dropped more than 1.5". |
^^ This. The H&R are usually slammed for the coupe.
I was reading that with the eibachs u can get away with the drop and wont really need a camber kit
Originally Posted by socialconflicts
(Post 3591736)
I have Coils and no camber kit. I am about -2 all around. Tires were rotated Tuesday and are wearing pretty even. *shrug*
