Cusco Rear Adjustable Toe Rod 370Z/G37 Cusco Adjustable A Arm 370Z/G37
Hello,
I am trying to find date on these, I know Cusco is very good name in the racing world. I want the best parts on my car, but I never seen anyone with these. Cusco Rear Trailing Arms 370Z/G37 http://www.z1auto.com/images/cuscoreartoearm370z.jpg These adjustable rear trailing arms feature pillowball bearings, replacing the stock rubber bushings. Allows adjustment of rear camber allowing you to maximize rear tire grip, and bring alignment back into spec. Best when mated to Cusco's rear toe rod. Cusco Rear Trailing Arms 370Z/G37 $445.00 $20.00 Cusco Adjustable A Arm 370Z/G37 http://www.z1auto.com/images/cuscoaarm370zg37.jpg New from Cusco Japan are these adjustable front a arms. At -30mm rideheight, they allow for up to a 10mm correction in camber. These feature a Japan sourced NMB pillowball bushing, replacing the soft factory rubber bushing Price: Shipping Cost: Purchase: Cusco Adjustable A Arm 370Z/G37 $649.00 |
Anyone? wow or are these parts too new?
Originally Posted by GTLAW
(Post 3571313)
I guess so! Anyone have a pic of the top of the arm? Curious to see how the camber adjusts. |
Finally! An option over the crappy SPC kits!
@OP, please post links to the parts.
Thanks Guys!
Here is the link! Yes I love the fact I don't have to Buy SPC! Z-1 Performance Automotive Services Inc. - Cusco Adjustable A Arm 370Z/G37 |
I'm surprised these haven't generated that much interest on this forum,...well not really.
They are very likely good parts, Cusco is a great suspension manufacturer. But they are ridiculously overpriced. It you've got a great reason you can justify the huge price difference between these and the SPC parts knock yourself out. Most people won't though.
AFAIK, front arms are NOT adjustable. They are permanently set. At -30mm ride height (little over 1 inches), they allow for up to a 10mm correction in camber.
IMO, they're not really worth the money. |
SPC parts are known to fail. That's the reason. At what price difference are you willing to accept this risk? I guess the SPC price point and...you may be knock yourself out...literally.
the cusco arms are not adjustable though. they only offer 10mm of correction at 30mm of drop. not worth it for the price. i would rather stick with the stock arms and just deal with the camber.
what is 10mm in terms of degrees?
Originally Posted by redrover23
(Post 3581838)
(Post 3582413)
I'm not convinced of this at all. I think SPC failure is being grossly exaggerated in the minds of some. There have been only a couple of legitimate parts failures that I'm aware of. Obviously neither of us knows exactly how many, but not very many for sure. Some failures due to improper use or installation, user error, are being counted in the SPC failures. That's not the fault of the parts. If I had any doubt that they weren't safe I wouldn't even consider them. I bought another manufacturer's suspension parts and returned them without even installing them taking a 25% hit on restocking fee. Why? Becasue they were clearly pieces of crap and not fit to be used on my car. So I don't have confidence in the SPC parts because they're cheaper. I have confidence in them because they rarely fail legitimately. If the only parts that worked properly cost as much as the Cusco ones or more then that's what I'd pay if I wanted to lower my car and still adjust the camber. I love Cusco. But these parts are still ridiculously overpriced.
(Post 3582381)
Ball joint sits at a 13" diameter on a 19" wheel. 10mm is 1/3" Almost 2 degrees |
