Headlight, off, not burnt out
Hey guys. Long time lurker here but I don’t post much. My my passenger side headlight I thought was burnt out. Bought one at O’R, $100, and proceeded to change it out. Bottom line is that the original is not burnt out. I have not done a search yet on this site as I am running out the door. If any one can please give me ideas, I would greatly appreciate the help. Thanks David 2008 G37S 105,000 |
You should probably start off by checking your fuses. If its blown fuse you might be able to get away with just swapping it, but there's a good chance there's another problem that made the fuse blow. If your fuses look good, grab a multimeter, unplug the bulb and check if it gets voltage with the headlights on.
My guess is it's the ballast. 08's Still came with hid's right?
Yes. They are the Hi’s |
I di$ not look st the fuse as I assumed both headlights would be on the same fuse. Are they on separate fuses?
thanks david |
Originally Posted by mahmoudg37s
(Post 4218413)
Originally Posted by Jsolo
(Post 4218457)
(Post 4218413)
thanks david |
more than likely the high voltage ballast is burnt out. i would check the wiring connections first, if the wiring is good then you would need to replace that ballast. i don't believe the ballast is sold individually so you may need to replace the entire headlamp.
