Notices
**HELP** Switchback wiring
Old 07-19-2014, 10:07 AM
Daddy Fat Sacs
Daddy Fat Sacs's Avatar
Trying to install switchback turns on my 10' sedan. There's 3 wires; green w black stipe, green w white stripe, and white w black stripe....which is neg and pos out of the 3????
Old 07-19-2014, 03:53 PM
telcoman
telcoman's Avatar
Have you tried searching for the FSM?
Telcoman
Old 07-19-2014, 11:42 PM
Daddy Fat Sacs
Fig it out shortly after posting....in case anyone ever needs it again tap into the white w/black wire and the green w/black
Old 12-07-2015, 08:09 PM
STownSaint
STownSaint's Avatar
Anyone know of double-side tape that is heat-resistant enough to secure load resistor?
Not trying to drill and bolt down in engine bay.
Old 12-07-2015, 09:13 PM
qmantran
qmantran's Avatar
I used 3M dual lock on my G37 for my Triton control boxes up front and load resistors for the rear tail-as-turn module.
Previously on my TL I used just plain white Scotch brand double sided tape to mount my load resistors. I actually mounted it to the top of the frame of my car so if the double-sided tape would have failed the load resistor would have easily fell off due to gravity. Well the double-sided tape never failed and over 1 year later I went to go remove it and it was a bitch to remove.
It wasn't a special rated double-sided tape like VHB or Industrial strength. Just plain white double-sided tape.
3M Scotch 1 in. x 1.52 yds. Indoor Mounting Tape-214/DC/SF - The Home Depot
Old 12-08-2015, 03:31 PM
tbulsara
tbulsara's Avatar
put the resistor on the rear turn signals.. easier to mount it there.
Old 01-05-2016, 09:48 PM
Daddy Fat Sacs
I actually used electrical tape to hold down the resistors. Haven't had a prob since day 1
Old 05-17-2018, 04:13 PM
alecwatersmusic
alecwatersmusic's Avatar
Have you done this? Do you know for sure they'll work for the front turn signals all the same?
Old 05-17-2018, 05:51 PM
slartibartfast
slartibartfast's Avatar
tbulsara hasn't been on the board since October 2016. Check his profile.
Old 05-22-2018, 11:40 PM
JustROLLIN
JustROLLIN's Avatar
Yes, but you need to look up what ohm resistor is correct if you are using LED on all four corners. I cannot recall off the top of my head, but I think its 4ohms. Look it up to be certain though.
If you are not running LED on all four corners, you need to go with the higher ohm resistor either up front or in the rear.
37
10-17-2020 11:12 AM
Rybitron
11-18-2015 03:11 PM
dedmanchan
09-24-2015 11:25 PM
SheLLz
09-24-2015 08:02 PM
RexHavoc
09-06-2015 01:03 AM
Quick Reply: **HELP** Switchback wiring
