Fog Light Removal
Fog Light Removal
Hello guys, I just discovered this site. I have a 2012 G37 Sedan and one of my fog lights are busted, the passenger side. I am at the point when I have removed the plastic tabs and pulled back the fender on the driver side. I have removed the screw holding the bulb in place, but there seems to be a plastic cage holding the actual light. I thought I could push the light out through the front, but I believe the chrome ring is holding it in place. Im stuck and need help. Im on the driver side if that is any help. Thanks. I have read how to remove the bumper, but really dont want to do that since I'm right there, and I have read the other posts btw. I need basic instructions on how to proceed. Thanks.
There's a good pic of the back of the fog light in this post: https://www.myg37.com/forums/d-i-y-i...-modified.html
That's them.. I do remember it being a snug fit and you have to push both at once. Granted I had the bumper off so I was easily able to push the tabs and pull on the bezel from the front. Since your Fog housing is unscrewed, you might try applying some light pressure (outward) to the back of the housing as you push the clips in.
Finally got the first one changed on the driver side. Thanks TBau651 and MaQG37. I can feel where to pull the light out on the passenger, but I'm gonna go ahead and take the plunge and take off the bumper. Is this a one person job, especially as far as putting it back on?
ok, the bumper removal was a resounding success. I just came right off. I really should have just taken it off to begin with, it would have been much easier, damn near dead simple. Used the shoe box trick to put even the bumper up and went at it. It snap right back into place, and my new oem replacement fog lights look great. I did notice while on this forum that I want new HID's and foglights, all white, with a slight blue-ish tint. I'll be doing that in a couple months. Thanks all. You guys rock!!!!!
https://www.theretrofitsource.com/mo...0#.V46C8PkrLcs
New to this site but I learned some stuff
Hello everybody I am new to this site and came across this post trough a google search, I believe I have an easier way to remove and change fog lights for a G37 coupe, I own a 2012 so I'm no sure if this will be the same with other years, it may help since this type of things are either similar of don't really change much.
This is for the passenger side since it's more difficult because the washer fluid is right behind the fog light, driver side is a walk on the park.
After you remove the bottom plastic piece which is very easy to remove.
you don't have to remove those.
Remove the plastic piece in front of the wheels, there are only clips.
I know, that is not an original clip since I messed those up the first time I removed them, they were old anyways.
You will have this view from the bottom of the fog light, the washer fluid container is behind the fog light but if you push carefully on those clips, the black plastic around the fog light will come out.
there are 4 of them, the other 2 are not visible but you have to squeeze your hand between the fog light and the washer fluid container, you can use your other hand to push the washer fluid a little so you can get it there
Now all you have to do is remove these screws.
and then TA-DA!
the ones on green are the visible, the red ones are the ones you cannot see, I swear I did not broke the clip, it was like that when I got here like seriously I had my bumper repainted so it must had been them.
Am I the man you may ask? well, yes, yes I am, good luck and hopefully this info helps you.
and then TA-DA!
GFTW
05-05-2016 11:29 PM
