Notices
LED v3 Triton Switchbacks + Other LEDs
Old 06-19-2016, 11:49 AM
  #31
qmantran
qmantran's Avatar
Originally Posted by Furlow
Did you install these? Curious what color you purchased and if you have any pictures?
I'm going to try these, but confused about 5000k or 6000k. I have the DD 5000k HID fog lights, and I ordered the 5000k DD headlight and city light bulbs. I'd like the color to match and from the OP's post, it sounds like 6000k is the answer.
Also wondering if for the sedan, do I need the standard or "CK" base?
Get 6000K.
You need standard socket. Non ck
I have 5000K tritons and you can clearly see in some of the pictures that it looks yellowish white compared my Osram cool blue intense headlight bulbs which are 5000K
Furlow (06-19-2016)
Old 06-19-2016, 11:52 AM
  #32
Furlow
Furlow's Avatar
Boom thank you.
Old 06-19-2016, 11:53 AM
  #33
STownSaint
STownSaint's Avatar
FTR I got the 5000K because I don't plan to change the OEM headlight bulbs. Haven't gotten to install yet, hoping the match is OK...
Old 06-19-2016, 11:58 AM
  #34
Furlow
Furlow's Avatar
Also do the amber VLED turn signals stay "on" like the switchbacks with the headlights on? If not I may go that route. The switchbacks seem really bright compared to the headlights, almost overpowering.
Old 06-19-2016, 12:47 PM
  #35
MaQG37
MaQG37's Avatar
I already mentioned this to you when you first bought them. The 5000K have a very noticeable yellow tinge. If you have OEM bulbs, it should be fairly close.
They have a wire to dim when the low beams are on.
Furlow (06-19-2016)
Old 06-19-2016, 12:51 PM
  #36
Furlow
Furlow's Avatar
Originally Posted by MaQG37
I already mentioned this to you when you first bought them. The 5000K have a very noticeable yellow tinge. If you have OEM bulbs, it should be fairly close. If you have an aftermarket like osram, morimoto... It won't match.
Nice. I wonder if this could be modified to turn off completely?
Old 06-19-2016, 01:31 PM
  #37
STownSaint
STownSaint's Avatar
^checkout out this post:
https://www.myg37.com/forums/audio-v...ml#post3514184
If you want turn signal off except when blinking to signal a turn, then you just need 7440 bulbs, which I believe work because they only have one filament. Buying Tritons to disable the switchback feature seems like a waste of effort/$$$ IMO.
Furlow (06-19-2016)
Old 06-19-2016, 01:59 PM
  #38
Furlow
Furlow's Avatar
Interesting option, good find. Hmm now that I see the headlights on without the turn signal, it looks a bit strange.
Maybe pictures are making the white led turn signal brighter than reality. I want to try it, but $180 is not cheap for an experiment.
Old 06-19-2016, 02:06 PM
  #39
STownSaint
STownSaint's Avatar
Here's a vid that can somewhat gauge how much brighter Triton is relative to stock bulb, the white light certainly competes more with headlight in terms of brightness. That said I don't think the headlights in the vid are OEM, seem much bluer.
This was a concern of mine as well, chose to bite the bullet when VLED had a 10% off sale,
Old 06-19-2016, 02:17 PM
  #40
Furlow
Furlow's Avatar
Vleds V3 triton g37s sedan - YouTube
Yeah I saw that video and that looks pretty close. I agree those are probably aftermarket headlights. If that was the difference i could live with it.
Old 06-24-2016, 11:42 AM
  #41
Furlow
Furlow's Avatar
Got everything installed last night, very happy with the result.
City lights - Diode Dynamics 5000k
Headlights - Diode Dynamics 5000k
Turn signals - VLED V3 Triton amber/white switchbacks 6000k
Fog lights - Diode Dynamics HID conversion 5000k
Diode Dynamics (06-27-2016)
Old 06-24-2016, 05:02 PM
  #42
qmantran
qmantran's Avatar
Very cleanly done Furlow! I wish i had gotten 6k instead of 5k
Furlow (06-24-2016)
Old 06-24-2016, 05:07 PM
  #43
Furlow
Furlow's Avatar
I took your advice, much appreciated!
Old 06-24-2016, 05:27 PM
  #44
STownSaint
STownSaint's Avatar
Looks great Furlow! Hoping 5K works well with OEM headlights...
Now that you've installed them, any tips on the process? Did you go thru wheel well or engine bay? Remember which of the rubber washers you used? How'd you mount the resistor? Anything else to look out for/make the install smoother?
Not expecting answers for all above, just throwing 'em out there.
Thanks!
Furlow (06-24-2016)
Old 06-24-2016, 05:36 PM
  #45
Furlow
Furlow's Avatar
Thanks!
Well I had a shop do them, but I was there the whole time paying close attention. He went in through the wheel well, and took the wheels off for more room. Made it VERY accessible so I'd suggest that for sure. The washer to use was obvious, the other choices made no sense at all. There are many options for the resistor, but I chose the vertical metal wall just below the air intake (I have the Stillen ram air) or where the airbox would be. He used a screw and the double sided tape that comes with the package.
Mainly I'd say don't try to rush it, and be patient when putting the switchbacks in, they take a while. He really had to muscle them in.
STownSaint (06-24-2016)
Quick Reply: LED v3 Triton Switchbacks + Other LEDs
