MyG37
MyG37 (https://www.myg37.com/forums/)
-   Body Interior Exterior Lighting (https://www.myg37.com/forums/body-interior-exterior-lighting-314/)
-   -   Coupe driver window doesn't dip down and up when open and close (https://www.myg37.com/forums/body-interior-exterior-lighting/266429-coupe-driver-window-doesnt-dip-down-and-up-when-open-and-close.html)
Eddystone Apr 12, 2015 02:10 PM
My 08 coupe driver side window doesn't roll down a quarter of an inch when opening and back up when closed. My passenger side works fine tho. Windows rolls down and up completely fine.
A part of the top of the glass touches the top part of frame due to it not going up and down when opening the door.
2008G-Man Apr 12, 2015 08:34 PM
Perform the window reset procedure ... in your manual or posted here about a million times.
Eddystone Apr 12, 2015 08:37 PM
That's the first thing I did before posting. I forgot to mention it.
Eddystone Apr 12, 2015 09:17 PM
I just noticed that the button on the bottom door pillar for when the door is closed, the door presses the button. When open, the button is released letting the car know that the door is open. The reason why the window doesn't work is that switch on the door pillar is not working.
Anybody know where I can get that part and how I can get that fixed?
Eddystone Apr 12, 2015 10:02 PM
SOLVED
It was the switch on the pillar, it was unplugged for some reason.
vqsmile Apr 12, 2015 11:56 PM
Originally Posted by Eddystone (Post 3895146)
SOLVED
SO you didn't happen to notice the connection between the seat belt and the window and made two totally separate threads? :confused2:
BTW, please look back at the spark plug thread you made 4 years ago. I just noticed you got some seriously bad advice in there and hopefully run those plugs you mentioned!
© 2026 MH Sub I, LLC dba Internet Brands
