Switchbacks, rears LEDs, and resistors ..... issues
https://plus.google.com/103085377584...77584501571003https://plus.google.com/103085377584...77584501571003
I've got a 2011 G37x sedan, with newly installed switchbacks and rear LED turn signals. I chose to get 3ohm resistors, 1 per set of switch back/rear LEDs. I also followed other threads about installing the 3ohm resistors in the rear, for ease of installation. I've got the resistor in place on the passenger side, but I'm still getting hyperblinking. While the fronts are 3 wire, I see the rear are 2 wire. I attached the resistor to the green and black leads to the rear connector. And hyperblinking occurs when the hid lights are off and in auto/running lights position. But when the lights are in the on position the hyperblinking does not happen. So the added system load, seems to So am I using the wrong leads?? and/or should try putting the resistors up front using the 3 wire connections ? Could the resistor not actually be adding a 3 ohm load? Is. I got sold 6ohm resistors as a set of 3 ohm resistors? Thoughts? |
