Driver window stuck down help..
Soooo I took off my door panels earlier to remove the accents so I can spray them cause they're scratched up anyway after I put the panels back on my driver window won't go back up, passenger works fine but my one touch for the window to go up won't work, don't know what else to do, I've checked fuses, connections unplugged the motor, tapped the motor I'm running out of ideas and don't have a garage to put it in til Monday .. Any help is appreciated
Scroll the windows up manually... Then scroll them down manually and hold for at least seven seconds... You're welcome...
How do I roll them down manually?
I figured out how to make the one touch work but driver window still stuck down lol that's my problem |
Try using the key in the door. If you hold it one way and the other both windows should go up and/or down. If the window works that way then at least you would know it was the switch. If it was your passenger window I would suggest making sure you did not accidently push the window lock. I did that once.
Close thread problem solved switch went bad
