MyG37
MyG37 (https://www.myg37.com/forums/)
-   Body Interior Exterior Lighting (https://www.myg37.com/forums/body-interior-exterior-lighting-314/)
-   -   Help 2010 Sedan Front LED turn signal won't blink when headlight/parking light on (https://www.myg37.com/forums/body-interior-exterior-lighting/257498-2010-sedan-front-led-turn-signal-wont-blink-when-headlight-parking-light-on.html)
PERMAT Apr 19, 2014 09:43 PM
Tried installing front turn signals from Diode Dynamics.
Decided to try living with the hyperblinking as I had tried splicing the load resistor (tapped the green/black and green/white wires), but it still hyperblinked and made my brake lights flash.
Removed the load resistor and placed electrical tape over the splice.
I proceeded to install the passenger side led bulb and it tested out fine. While on a drive just now, noticed the turn signal were not flashing (stays lit). Turned on my hazards and noticed they flash when I turn off the headlights. How can I fix this?
Edit
Was able to find the stock bulbs and replaced the LED bulbs with those. It is working as normal.
Just realised I bought the wrong bulb from Diode Dynamics (2009 Front Turn Signal)...
© 2026 MH Sub I, LLC dba Internet Brands
