Fog light trim ring removal?
Anyone know how the fog light trim ring removes? I was thinking maybe there are clips from behind but before I pulled it in the garage, dropped the shield and all if that's where it was for sure?
I'm wanting to check the options about painting or plastidipping it. |
Originally Posted by Damn Dirty Ape
(Post 3534833)
I'm wanting to check the options about painting or plastidipping it. No worries, you damn dirty ape. You just need to remove the fog light assembly. And while that's easy enough, it's also a minor PITA. Check out the FSM, it's a big help. Wait... I wrote this up not long ago. Go here and see Post #47: https://www.myg37.com/forums/g37-sed...mber-fogs.html |
(Post 3534840)
Somehow I knew this was coming based on your comment in your window trim thread. :p
(Post 3534877)
think it's possible to get to the trim ring clips from behind without popping that whole assembly out?
(Post 3534888)
I think so, yes. But you have to do it by feel unless you completely remove the wheel-well lining, which probably isn't going to happen.
Adding the LEDs adds a couple of brackets and makes it several times harder to get to. How to paint with them on the car...... hmmm
Has anyone figured out how to do this with a sport bumper with the OEM front lip/spoiler?
