MyG37
MyG37 (https://www.myg37.com/forums/)
-   Body Interior Exterior Lighting (https://www.myg37.com/forums/body-interior-exterior-lighting-314/)
-   -   Autokits diffuser + Tanabe's = FAIL?? (https://www.myg37.com/forums/body-interior-exterior-lighting/208739-autokits-diffuser-tanabes-fail.html)
myk1013 May 25, 2010 08:19 PM
Hey guys.
Just had the time to install my cf Autokits diffuser yesterday. Looks good and all but my passenger side exhaust sits a tad higher than the drivers side. It's about 3-4 mm from touching the cf diffuser. The heat from the passenger side exhaust has already started to burn the diffuser. I've been stepping on the exhaust to push it down but no luck.
What do I do?
deepFlip May 25, 2010 08:23 PM
post pics bro
emyrl May 25, 2010 08:27 PM
Hmm, maybe you can add some washers to the exhaust hanger on the passenger side to have the mufflers/tips lowered a little? I'm not sure if this would work cause I'm not an expert at this, maybe other people can help you out.
Black Betty May 25, 2010 08:30 PM
You can adjust the tips. Heat the exhaust hanger on the top of the muffler with a torch. When it's hot and soft, adjust it a little higher (away from the body of the muffler) so it sits slightly lower. Be careful not to heat it too much and cut through the hanger or you'll have to weld a new one back on. Also don't adjust it too much or it will sit too low and be uneven.
chris9012 May 25, 2010 08:30 PM
Yup i failed my tanabes hit the top of my autokits-x diffuser and now the paint is chipping from the heat
I have to take it to an exhaust shop to lower it with the hangers but im way too slammed for any regular shop to deal with me.
VossenG37S May 25, 2010 08:58 PM
Same with my Fast Int Catback ! Not the diffuser but my exhaust sits slightly higher on tight tip causing it to touch diffuser and melting it where heat shield is at, hate the headache so I just took it off .
Kidcane May 25, 2010 09:57 PM
That sucks. Did not have this problem with SE Diffuser. Just sayin.
camp3r May 25, 2010 10:04 PM
Agreed....+100000 for SE diffuser....perfect fit for me!Best one out there!I dont care what people have said,maybe their install was crap!
myk1013 May 26, 2010 11:48 AM
Guys, let's not make this into which diffuser is better. I'm sure your SE diffuser is pimp. I never said the fitment on the Autokits is off. That is not the case. It's my exhaust, the passenger side is a few mm's higher. Not as obvious before but it is now. Anyways, I kept stepping on the exhausts and putting my weight on it, looks like its working. I'll see if I can bend the exhaust hanger a little tomorrow.
© 2026 MH Sub I, LLC dba Internet Brands
