G37 Coupe Spoiler (Must I Drill?) (Camera Cut Out?)
I'm looking at adding a spoiler to my G37 Coupe with rear view camera. Based on my review of the forum, a Grubbs or OEM spoiler appear to be the best ones to get.
I also found a write up "https://www.myg37.com/forums/d-i-y-i...r-install.html" that implies that there may be a way to install the spoiler without drilling holes in the exposed areas of the trunk. In other words...drilling only in the area under the chrome lip or just not at all.
Anyone who has added a spoiler care to chime in on opinions or comments regarding the drilling and if drilling can be limited to areas under the stock chrome finisher?
Last Question...does the spoiler "cut-out" block any of the cameras field of view?
So, to clarify, does the Grubbs spoiler have screw holes or something inside it for the stock camera to attach to?
Great...and that last photo answered another concern I had regarding the camera hole itself. Someone else posted that the Grubbs spoiler has a round camera hole, but yours is clearly square and best of all clearly not a "cut-out". Easy to see that its mounted in the spoiler for sure.
Guess the other posters had the V1 Grubbs spoiler. I dunno.
Thanks again for your replies. I think the Grubbs V2 is the way to go here.
I was the one who posted that my hole was round. I was able to find a rubber washer and used it to go between the camera and the hole so it provided a waterproof "fix". My spoiler also did not seem to fit quite right but that could have been my fault. All in all it still looks good and I don't have any problems with the camera although it does look like you're looking through a tunnel. My color was Amythest graphite and it was a great match. I bought mine in February '09 from Grubbs
Yeah, I would've but when I was fitting it on the car, I had it sitting on the trunk deck and I walked off for a second and it friggin' slid off onto my pebble driveway and got nick marks in the paint job. I about lost it and now it was unreturnable. AAAARRRRGGGHHHH!!!!!! Never even called Grubbs. I am living with it and touch up paint has helped some. The round hole does not look bad, it just took some innovation to make the camera look good in it.
I wanted to see if it's possible for me to install a sipper on my 09 g37x. I have the chrome lip and I'm looking to get rid of it and add the spoiler with the break light as it will make it look way nice. Is it possible for me to do this?
The camera is attached to the chrome spoiler. Take out the chrome spoiler and unscrew the camera from the chrome piece. Installed the camera into the fiberglass spoiler. I have to drill some holes on the trunk to attach the new spoiler. But if you don't want to drill hole, you can use 3M 2 sides tape and also 3M adhesive sealant 5200 fast seal for fiberglass (In red tube purchase from Home Depot for $13). This adhesive is permanent glue the spoiler to the bumper without drilling any hole. I used this adhesive on my front lip for my G37 Coupe (see my pictures in my profile). Good Luck!!!
Chris Olson
03-28-2024 09:46 AM
i heart ricers
12
12-09-2015 04:15 AM
