Notices
Engine Bay Thread
Old 04-11-2018, 10:44 AM
  #481
aarr_ttyy
aarr_ttyy's Avatar
Blanking plate.
I'm already in the process of making one of those (hence the one piece rubber strip). On version 2 at the moment. It'll eventually be done in carbon fibre to match the other 2 panels.
Looking at your engine bay, clearly I'm not the first person to think of using a single piece of trim-seal back there. [/QUOTE]
Old 04-11-2018, 10:57 AM
  #482
Received 4,574 Likes on 3,425 Posts
"Blanking Plate", huh? Never knew what I should call it, and that makes sense. Thanks!
I think the breakthrough moment was when I realized the easiest mounting technique was to use push rivets into newly drilled holes at each side. Good luck with your project. Love to see your final work. Interesting choice that you're using aluminum instead of plastic. It certainly gives you more options to cut and shape it however you need.
Close-up photo on the CF wrap over the center of your engine cover, er-r-r... that's no bueno, buddy. Sorry.
Old 04-11-2018, 11:00 AM
  #483
aarr_ttyy
aarr_ttyy's Avatar
I'm also a dealer for TommyKaira products (I live in Japan), hence the turtles. There are actually 4 of them in this engine bay, the other being the oil dipstick cover. I use the car to showcase new products. But you're right in that there are more TK products inside the car. However, this is not really overkill, as TommyKaira did produce a V36 Skyline sedan and many of the parts on my car are those original V36 TK parts. For example interior carpets, kickplates, airbag cover, interior clock, trunk spoiler etc.
Old 04-11-2018, 11:02 AM
  #484
aarr_ttyy
aarr_ttyy's Avatar
its actual carbon fibre (raw with a protective coating) but is going to be completely redone, carbon fibre skinnned and resin coated.
Old 04-11-2018, 11:04 AM
  #485
I'm not surprised you're working that. With all you've got here, that doesn't seem like the kind of thing you'd give a pass on.
Awesome work overall, buddy.
Old 04-11-2018, 11:07 AM
  #486
aarr_ttyy
aarr_ttyy's Avatar
Like this interior piece that I finished last year. It's just extremely messy and time consuming to do, so haven't got around to doing the engine bay pieces yet.
Old 04-11-2018, 11:55 AM
  #487
aarr_ttyy
aarr_ttyy's Avatar
In case anyone else here is liking these P2M hose clamps... I received an email from them this morning:
[edit]
...and I've got one in the mail right now.
I'm using them on my intakes. But swapped out the bolts for titanium since the chrome started to rust.
Old 04-11-2018, 12:14 PM
  #488
I'm looking at your burnt-ti allen bolts at the throttle bodies. Often thought of doing that with polished Ti; (don't like the burnt look).
Very nice.
Old 04-11-2018, 12:16 PM
  #489
Stachuu
Stachuu's Avatar
Hey aarr_ttyy, I see you used noise suppressors on your MAF's harness. Just wanted to say its pretty cool idea.
Old 04-11-2018, 06:38 PM
  #490
jpowersjr2
jpowersjr2's Avatar
aarr_ttyy - Wow....just....wow.
Old 04-12-2018, 02:10 AM
  #491
aarr_ttyy
aarr_ttyy's Avatar
Polished Ti looks great too, much better than the cruddy blackish/greenish OEM bolts. I just have them burnt to match my intake pipes.
Very nice.
Old 08-10-2018, 10:24 AM
  #492
Entcee
Entcee's Avatar
Old 07-26-2019, 01:49 PM
  #493
BULL
Moderador
BULL's Avatar
Bump from the dead. Here's the one on my daily
Old 07-26-2019, 01:51 PM
  #494
BULL
Moderador
BULL's Avatar
Next one will probably be the G37.
I already hid away the light harness, tackling the power wire routing soon.
These two things clean the engine bay up so much
Old 08-01-2019, 04:47 PM
  #495
Baadnewsburr
Baadnewsburr's Avatar
I like the painted valve covers, I have had some plastic adhesion promoter and red crinkle coat along with new gaskets sitting in my garage since last year waiting for a similar mod...kinda sucks the way the engine is designed between the cover and the
I can never tell what to do to tuck wires, but it always seems to look better than normal...even if I cant tuck em I'd like to replace the cracking plastic coating on the harnesses running around the engine bay at some point on my car with something more durable. my biggest concern is upsetting the dried out wiring and not wanting to unplug wiring unless necessary...all other things I'm up for but I really don't like messing with wiring lol
Quick Reply: Engine Bay Thread
