Help Both key fobs don't work after changing batteries
Old 05-25-2018, 08:30 AM
bourne9449
bourne9449's Avatar
Exclamation Both key fobs don't work after changing batteries
I have a 2012 Infiniti G37s coupe. I have two keys for it that worked fine. One key started to act up about a year ago and take multiple tries to unlock the car. I figured the battery was low, which my multimeter confirmed, and replaced it. With the new battery, the buttons will not work on the fob to open the door, trunk, or start the car like normal. It WILL start the car if inserted into the slot on the dash. I figured the fob went bad so I switched to the other key.
Now I've had the same exact issue with the other key after changing the battery in it. I'm using CR2032 batteries, as required. Is there some procedure I can do to "re-pair" the batteries? It seems unlikely to me that both fobs just went bad slowly like this and then completely broke when the battery was replaced. What's going on here?
Old 05-25-2018, 09:45 PM
saywat?
saywat?'s Avatar
i noticed it doesnt like some batteries. i had the same issue so i specifically changed it with the exact same batt that was in there when it was working.
Old 05-25-2018, 11:39 PM
Surfnazi
Surfnazi's Avatar
Make sure the contacts are clean and remote is seated right in the housing
Old 05-27-2018, 04:19 PM
bourne9449
bourne9449's Avatar
I think that getting the same exact battery may work. It seems very strange, but it's worth a shot.
Old 05-27-2018, 05:03 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Check polarity.. Make sure new batteries actually work (tongue test¿?).
Old 06-16-2018, 10:26 AM
airlia101
airlia101's Avatar
@Bourne9449, did you resolve this? I'm looking for any/all key info today.
Old 06-17-2018, 04:43 PM
bourne9449
bourne9449's Avatar
Thank for reminding me to follow up! I bought some other CR2032 batteries (energizer) and they work perfectly in both fobs. Why these batteries work great and the others did not, I have no idea. "Saywat?" had just the right idea! Thank you
Old 06-18-2018, 02:38 PM
saywat?
saywat?'s Avatar
lol yea its weird. only thing i can think of is something to do with the negative side of the battery some are smooth and some are textured
frank37
02-21-2024 09:05 PM
Matty_baby
Picture Share G Coupe
21
02-06-2019 03:09 AM
Quick Reply: Help Both key fobs don't work after changing batteries
