Help Hardwiring a Escort radar to 2011 G37 sedan
Old 08-17-2017, 06:35 PM
Snappingturtle
Snappingturtle's Avatar
Hello all, I was looking to hardwire a Escort radar to a 2011 G37 sedan. The proper size is low profile mini fuse right? I was searching around the internet on how to use an add a circuit/fuse and I still am not sure how to properly use one. The add a circuit has 2 slots for fuses. I know one of them is for the fuse that you took out to plug the add a circuit in. Which slot would I put the original fuse back into? Also what amp fuse should I put in the second slot to be used for the radar detector? I read somewhere that it should be the same amp fuse? Is this correct? The lowest amp fuse that I see is 10amp. Thanks!
Old 08-21-2017, 05:45 AM
Surfnazi
Surfnazi's Avatar
Just tap power from mirror
Old 08-21-2017, 07:33 AM
Mr_Mer
Mr_Mer's Avatar
This:
Amazon Amazon
Old 08-28-2017, 12:01 PM
blazeplacid
blazeplacid's Avatar
I made a simple DIY install a few years ago....
This same cord will fit Valentine an Escort/Bel tronics
https://www.myg37.com/forums/audio-v...t-install.html
Old 09-01-2017, 04:29 PM
Surfnazi
Surfnazi's Avatar
You can make one with phone or network cable take a 10 mins
