Audio, Video & Electronics Reviews on G Audio, Video, and Electronics.
Review 128GB SanDisk Ultra Fit Flash Drive
Old 02-16-2016, 05:11 PM
dwb993
dwb993's Avatar
Thumbs up 128GB SanDisk Ultra Fit Flash Drive
Amazon.com: SanDisk Ultra Fit 128GB USB 3.0 Flash Drive (SDCZ43-128G-G46) [Older Version]: Computers & Accessories Amazon.com: SanDisk Ultra Fit 128GB USB 3.0 Flash Drive (SDCZ43-128G-G46) [Older Version]: Computers & Accessories
Tested out the USB drive feature on my '13 G37xS with a spare 4GB thumb drive I had laying around. It worked very well, so I upgraded to this SanDisk 128GB unit. It literally is the size of your thumbnail and takes up next to no space in the center console. Large capacity, USB 3.0, compact size, cheap cost---it's perfect!
Old 06-23-2017, 02:37 PM
bmarshall8
bmarshall8's Avatar
Cool. Good idea. I'm going to try it with one of my old MicroSD cards and compact USB adapters.
Old 06-23-2017, 05:00 PM
slartibartfast
slartibartfast's Avatar
Hope you have the nav system. Non-nav (like mine) are limited to 1,000 files for music playback.
Old 06-23-2017, 05:49 PM
Crazyirish
Crazyirish's Avatar
I have an '11 with Nav amd I havent found a larger USB drive that my car will even recognize. Admittedly I haven't tried but a few.
Old 06-23-2017, 11:32 PM
slartibartfast
I plugged a USB hard drive into my non-nav and the system wouldn't acknowledge its presence. I have a 64GB flash drive in there now that adheres to the 1000 file limit and it plays my music just fine.
Old 07-11-2019, 07:25 AM
kicksdechris
kicksdechris's Avatar
Good to know. I was curious to know what the largest capacity drive our vehicles would recognize because I’ve tried a 1TB and 512GB and neither of them are recognizable. I guess I’ll try a 128GB
Old 07-11-2019, 03:14 PM
slartibartfast
Unless your file structures meet the system requirements, the system will not recognize the drive regardless of size. I'm running an 8GB drive with my non-Nav system. Sadly, it will support only 1,000 total files and only 128(?) files in the root directory. I have four folders, each with 249 tracks using 6.21GB total.
Old 07-11-2019, 04:18 PM
dwb993
dwb993's Avatar
On my 2013 Bose Navi, it works just fine.
Old 07-11-2019, 04:39 PM
kicksdechris
As long as the format is FAT32 is should work however their seems to be a limit to the size of thumb drive u can use. So far someone has mentioned they’ve used a 128GB. I’ve used a 512GB and a 1TB and those are unrecognizable even with only maybe 20 songs on the drive.
Old 01-06-2020, 05:52 PM
_Bach_
_Bach_'s Avatar
Yes, you must prepare NTFS file system, which can work with big amount of data.
MrCupcakez
09-26-2010 09:27 PM
itspkallday
04-12-2010 08:48 PM
SCWells72
02-12-2010 01:23 PM
GG_37
10-29-2008 01:15 PM
ivory37
09-11-2007 04:32 PM
Quick Reply: Review 128GB SanDisk Ultra Fit Flash Drive
