How I displayed the Stock Screen on a Nexus 7
#136
Also, if you have even a decent set up, I HIGHLY recommend using a DAC. The headphone out from the DAC sounds much better than the Nexus headphone out. Well worth the money.
I'm using the optical out. Its feeding my Audison Bit ten. The optical connection really makes all the details sound their best. Anothergood part about the DAC is the RCA output. The DACs RCA out will provide a clean signal to your amps. This way you can run an amp from the DAC/Nexus 7.
#138
What I plan to do is hook the DAC up to the tablet (via USB), and also have an auxiliary line to the DAC so that I can hook up any device (via 3.5mm audio plug converted to RCA so it can plug into the DAC). There will be a switch to change between the two.
Also, the output of the DAC I plan to have connected to a 4PDT relay. If I also connect the XM radio wires to that relay, and the output of the relay to the receiver, I can switch between XM radio and Tablet/Auxiliary Audio. I created a wiring schematic using a free CAD tool I found, so if anyone is interested in seeing that let me know and I'll post it when I get home. The end result will hopefully be something like this:
- Change Source to XM on the G37
- Use switch #1 to control relay to change between (XM) OR (Tablet or Auxiliary)
- If in (Tablet or Auxiliary) mode, switch #2 will toggle the audio between the (Tablet) and (Auxiliary) lines
P.S. If I end up getting the amp, the output of the DAC will be hooked up to that, and then the amp will be hooked up to the 4PDT relay.
#139
I've been working on this install this past weekend. Got the audio to work thru the headphone jack of the nexus 7 by splicing into the xm input. Using the wieya/febon I was able to display the stock screen on the nexus 7 however the only thing that did not work was the backup cam. Every time I put it in reverse it would just show a solid blue screen. Any input?
#140
It is also worth mentioning that the video display wiring harness still needs to be hooked into the stock LCD circuit board in order for it to work. This is because the stock LCD circuit board sends signals back to the AV Control unit telling it that is receiving signal. You don’t have to have the LCD screen itself hooked up, just the circuit board that is immediately behind it.
#141
Ya I still have the lcd circuit board hooked up, I spliced into the wires of the 24 channel port that goes into the back of that board, following the original instructions.
#142
Did you ever do the video bypass hack in the past? If you did you need to reverse it for the display to work properly. I learned this the hard way!
#143
Essentially would this work with an ipad mini? I know it would fit size wise. I've read through all the steps (but skimmed some of the comments) and it seems as if the process would be pretty much the same?
#144
Ipad mini might require some modification to the trim being that its 7.9" vs the Nexus 7".
It will work but some of the apps listed above may not be in the app store.
Parts are called different things but they are essentially the same.
Google soundman or other ipad in dash installs to get a parts list.
#145
#146
#147
1. FEBON168 UVC HDMI GRABBER CARD work on NEUXS7 ISSUE
without root on nexus7, uvc device can work on nexus7.
APK: UsbWebカメラ
GOOGLE PLAY:
https://play.google.com/store/apps/d...t.usbwebcamera
the table as below link is my test
FEBON: [NO root ] NEXUS7 2013 vbersion /Samsung with Android 4.4.2 (Android 4.4.3) can let UVC device work
2. FEBON168 UVC HDMI GRABBER CARD have two version
it have 720p version and 1080p version
all of two version supprt 1920x1080i now
1. 720p version
Download link -720P VERSION (with Plastic case)
all of hdmi input resolution scale down/ up into 1280x720p output
2. 1080p version
Download link -1080P VERSION (with Plastic case)
Full screen : HDMI input resolution = UVC output resolution
CROP: HDMI input resolution > UVC output resolution
NO VIDEO: HDMI INPUT resolution < UVC output resolution
APK: UsbWebカメラ
GOOGLE PLAY:
1. 720p version
2. 1080p version
#148
If that's not the issue, a blue screen means that the febon is working but it's not getting an input signal. How did you tap into your video signal wires? The red, green, blue, combined sync, and signal ground should be cut and go directly into the cv-04. Meaning, there should be no input into the original LCD circuit board from these wires and they should be directly diverted into the cv-04. If you choose to power your cv-04 from the LCD wires (the 9v it supplies is sufficient) you need to splice a branch off of the + and - wires so that power is still being supplied to the LCD circuit board.
Other things I can think of is make sure all of the potentiometers on the cv-04 are turned all the way up and it is switched to NTSC instead of PAL.
#149
Wow Andy Febon himself posting on this board. Hey Andy, in order for us to use the Febon hdmi grabber we need an android software that supports the 1366x768 resolution which I have not been able to find.
Here's the problem. The only available CGA to HDMI converters have the following resolution outputs:
1360x768
1024x768
800x600
640x480
Your HDMI grabber accepts:
1920x1080
1280x720
1366x768
720x480
So the closest match is the 1366x480 resolution.
Can you help us find some android software that supports this resolution? I have both the CGA to HDMI converter and the FEBON HDMI grabber but due to lack of android software I have given up on them.
1360x768
1024x768
800x600
640x480
1920x1080
1280x720
1366x768
720x480
