Best way to play Spotify on 08 g37?
I have an 08 g37 with Nav and iPod integration but curious now years later how to play Spotify in my car. I know the newer ones have bluetooth and other options, what options do I have, just an RF Transmitter???
Anything direct wired or accessories to play Pandora or Spotify from an iPhone on the 08 g37?
Thanks,
Shane
Thanks,
Shane
open your glove box, you should have rca inputs. buy a mini to RCA audio cable and plug them in from your phone to your glovebox inputs. then click on aux on your radio. Start playing whatever you want and it should play through the cars speakers.
Doesnt the RCA inputs only work for Video when car is parked and ebrake on?
I have RCA, what options do I have for audio/ apps on iPod Touch when car is moving to play Spotify in Aux? Thanks,
Shane
Shane
nope.. you can listen to the audio portion when the car is in motion, just the video would cut.. this is what you needDynex 6' MinitoRCA Stereo Audio Cable DX-AD104 - Best Buy
you will be able to play audio from your phone or any other audio device with a head phone jack. I did it in my 08 before I had a 12.
here are some wireless options via bluetooth...
i have the belkin and it worked great!
Amazon.com: Belkin F8Z492TTP Bluetooth Music Receiver: MP3 Players & Accessories
Amazon.com: CoolStream Bluetooth Receiver for iPhone Dock.: MP3 Players & Accessories
Is there a car charger for power supply for the Belkin F8Z492TTP Bluetooth Music Receiver?
You can get an RCA to 3.5mm adapter on monoprice.com for a lot less than Best Buy or other retail stores. Great quality too.
http://www.monoprice.com/products/pr...seq=1&format=2
I used to have that cable but wanted to reduce clutter so went with a different solution instead. Bought one of these adapters:
For only $0.42 each when QTY 50+ purchased - 3.5mm Stereo Jack to 2 RCA Plug Splitter Adaptor - Gold Plated
Then I bought a retractable 3.5mm cable. Either solution works.
Or if you REALLY want to go completely wireless, get a bluetooth adapter like some have mentioned.
Would this work with the 3.5mm and RCA cord I have now?
For only $17.11 each when QTY 50+ purchased - Bluetooth™ Music Receiver - Black
Amazon.com: Britelink Bluetooth Audio Receiver: Portable, Bluetooth Music Receiver with Stereo Output (3.5 mm) for Home and Auto Stereo Systems: Electronics
you might be able to find a power tip off this site.
Power Tips - Power at iGo, Inc.
but i cant tell you which one to use. sorry.
edit: one thing to consider is that unit on monoprice has a power button, so i assume that you'll have to manually power on/off, (this is annoying because if you forget to turn off the unit, when you leave your car your phone will still be paired to the BT receiver) where as the belkin automatically turns on/off when the car starts/is turned off. but the belkin wont auto connect (at least my iphone 4/4s) and i had to manually pair the devices for each usage. just things to consider when your getting one of these.
i did use the britelink BT receiver as well in my car for a bit and it auto connected to my phone but i had to turn on/off. which was annoying to me.
ultimately i ended up just using a dock from proclip and using it that way. no more bluetooth for me.
