iPod cutting out in '08 Journey...
When I connect an ipod to the factory connector it gets recognized and plays for about a minute, then loses its connection. (iPod not connected message appears on the nav window) It also fails when I tuck it into the storage compartment. Have tried three different iPods with the same behavior. Any history of problems with the factory cable or connector in the console? The car is under warranty but the closest dealer is over an hour away so I don't want to make the trip unless it is really necessary.
It sounds like the cable to me. I have an '08 Journey and use the adapter so the newer i-Devices charge, I have to get in it just right or it looses the connection. Not sure that is something they will replace under warranty, I would call first. I can hear it now, "normal daily use wear & tear"
You also need to way the gas cost vs the cable cost :-)
it sounds like the cable to me. I have an '08 journey and use the adapter so the newer i-devices charge, i have to get in it just right or it looses the connection. Not sure that is something they will replace under warranty, i would call first. I can hear it now, "normal daily use wear & tear"
you also need to way the gas cost vs the cable cost :-)
Old school, but my recommendation: http://www.dabonwheels.co.uk/sendbin....JPG&width=275
Haven't had a problem yet with these. Got them for $10.
yeah its the wire had the same problem guess the plastic on Infiniti connection side isn't that great.
@ayarj12 u should go the somewhat new school way and get the iPod compostite cable and you can play video and charge as well as just music.
I have the same issue and the OEM at the stealership is $38.. Could you send me a link where i could get one for cheaper because this cord takes 50 cents to make -___-
37
10-17-2020 11:12 AM
4DRZ
10-14-2015 01:51 PM
dedmanchan
09-24-2015 11:25 PM
