MyG37
MyG37 (https://www.myg37.com/forums/)
-   Audio, Video & Electronics (https://www.myg37.com/forums/audio-video-and-electronics-310/)
-   -   Can't install Stealth Cord. (https://www.myg37.com/forums/audio-video-and-electronics/189503-cant-install-stealth-cord.html)
jerrt Jan 15, 2009 02:30 AM
Hi Guys, I just ordered the stealth cord but I found that I have problem to install it properly. I know the black wire should go to the ground slot while red wire should go to the power slot. But I can't press those two probes....I tried very hard but they just don't fit in. Can someone tell me how to install those probes? Or how hard when you press those wires? Thanks in advanced.
STOOF Jan 15, 2009 02:33 AM
You really gotta push em in there.
I had a hard time too.
What i did was pop apart the plug, youll see its actually 2 pieces, then i was able to put the probes in and snap it back together. Havent had any issues at all.
Staples Feb 12, 2009 06:58 PM
bump, i got my stealthcord and had an issue with the black prong too. It actually broke on me, so I'll have to stop at my local radio shack and try to buy two new prongs. :mad:
vukhey Feb 12, 2009 07:18 PM
I just got mine yesterday, had a hard time too, the probe was bent in all ways cos i tried to force it in, what i ended up doing was getting a pair of pliers, the one with the flatter tip, and pinching the tip of the probe so that its slim and flat, didnt make it a lot easier, but i was able to get it in, and now its working great. hope that helps
Blackjack Feb 12, 2009 07:20 PM
Use a pair of needle nose pliers to hold the node and and to push it in. This gives you a bit more leverage.
Staples Feb 12, 2009 07:22 PM
Thanks for the headsup guys, but I shouldn't had to due to "HOW EASY" it was going to be from the installation video. lol
aznutx Jul 25, 2009 09:53 PM
i just broke mine too :(
now the prong is stuck inside, um the black/white part of the plug comes apart? i tried i couldnt get it apart.
anyone wish to help?
Pip Jul 25, 2009 10:55 PM
Remove the broken piece from the mirror with a pair of needle-nose pliers or even tweezers. Even up the end of the stealth cord where it broke with a pair of wire cutters. Strip off about a quarter of an inch of the insulation and soak a drop of solder into the end of the stranded wires. Careful not to melt the hell out of the insulation. When this cools, shove it into the mirror connector with a pair of needle-nose pliers held just behind the solder.
nestle_!9 Jul 25, 2009 11:08 PM
x2 ,, thats what i did
aznutx Jul 25, 2009 11:35 PM
i did use a needlenose and the black went in rather easy to the black, but the red... is where i spent a good 10mins trying to get in, and eventually snapped as it went to the brown... and pretty deep in to where i cant really pull it out even with tweezers so kinda need to get to it another way
i figure if i can pull apart the plug like one person mentioned, then i could just kinda clamp the exposed wire in there without soldering cus i dont wanna buy a soldering kit cus my old one doesnt work anymore
'TardPatrol Jul 26, 2009 01:22 AM
A pair of pliers is good but will actually just make it easier to bend the probe you're trying to insert. If it's too small a hole, the probe is gonna bend, period. The solution is to get a nice thick needle or something stiff and pointy like that, a little bit bigger diameter than the probe. Grab that with your pliers and jam that sucker into the area you want the probe to go, wiggle it around a bit and it will make just a little bit more room for the probe which will now fit; easier to insert, but still snug. So easy, a caveman can do it.
jnguyen Jul 26, 2009 03:12 AM
I didn't think it was that hard. Took me less than 10 seconds
Kidcane Jul 26, 2009 03:13 AM
Um the instructions say to use needle nose.
kingkong79 Jul 26, 2009 09:12 PM
I just picked a corner, pushed the harness wire a little up and applied pressure to the prong and it went in with a little force.
speedracer g37 Jul 26, 2009 09:17 PM
invisichord makes two different sized prongs for their product. i had a problem with inserting the leads, so they sent me their thinner pronged version.
© 2026 MH Sub I, LLC dba Internet Brands
