Anyone have problems with the intelligent key?
Lately I've been having problems with the intelligent key. Starting about two weeks ago it's been 50/50 when I try to open or lock my doors while the key is in my pockets. Half the time I press the button on the door handle and nothing happens. I don't think it's a battery issue as I can start the car 100% of the time, and can use the key fob buttons to lock/unlock the car. So weird.
Anyone have similar problems? I hope it's a simple fix.
Usually I have my Blackberry in the left pocket, keys in the right pocket. I haven't had any problems with this at all in the first 6 months I've had the car, it started in the last two weeks.
When it doesn't want to work, it won't even work if I have the keys in my hand as I am pressing the door button with the same hand. The key fob can be literally 2 inches from the door and I still can't unlock the door with the button on the handle.
I would think that a dead battery in the key fob would make this happen all the time. The fact that it happens inconsistently is driving me nuts.
You charge the key fob battery by sticking it in the little slot down to the left of the steering wheel, right?
I have a long drive this weekend, I'll see if charging the fob will make the issue go away.
Is it in the same packet as magnet?
If by "charging the fob" you mean sticking it in the socket to the left of the steering wheel then I think you should know that that socket is not a charging port. There is no "charging the fob". The port is there for you to be able to start the car in the case of a completely dead fob key.
The inconsistency makes me think that it's a LOW battery or bad contact. Do you get a fob battery warning in the center crystal display? Get it changed for 6 bucks and if the problem persists, take it to the dealer.
__________________
__________________
OR could it be the button on the door handle...hmmm? If the problem occurs on both sides the same way, THEN I'd say it's completely the fob. eh, just a guess. The problem is, that's probably a $2000 button
jon
__________________________________________________ _______________
'08 G37S Black/Black 6MT | Navi | Premium
Get your wrong on:
http://www.sheepholetees.com/main.php
jon
Get your wrong on:
I have this issue as well. I have been dealing with it almost a year and no solution so far. Its so random, sometimes its the trunk wont open or the driver door. I have 3 fobs and tried them all with new batteries, etc. No go. I have to keep pressing the buttons on the fob 7-8 times sometimes to get it work. Since the problem occurs with all 3 fobs and locks, I am suspecting that there is a malfunction in the signal receiving system. I checked the service manual and there are multiple wireless transmitter/receivers for the key fob on this car. They wont be all failing at the same time so, I am not sure where is the problem at this point.
Any suggestions?
Any suggestions?
Any suggestions?
Any suggestions?
