Everything you need to know about iPod Video Cables
2 Attachment(s)
Since the question regarding which cable will allow their iPod to play videos on the nav screen seems to come up every week, I’ve decided to do start a new thread with (hopefully) all of the answers to your questions regarding each type of cable and which iPods are compatible with them.
Apple iPod AV Cable This cable is only compatible with the iPod with Color Display and the iPod with Video. It plugs into the headphone jack to pull the video feed from your iPod and on to your nav screen. You can use a cheaper third party cable as a substitute as long as the connections are the same. Attachment 77091 http://store.apple.com/1-800-MY-APPL...&nplm=M9765G/B Apple Composite AV Cable This cable is compatible with all of the newer generation iPods such as the 3rd Generation iPod Nano (fat one), iPod Classic, iPod Touch, and the iPhone, as well as the older models such as the iPod with Color Display and iPod with Video. This cable plugs into the dock connector at the bottom of the iPod to play the videos on your nav screen. At the time, you cannot use a third party substitute for this cable since Apple has incorporated a chip somewhere in the cable that will allow the iPods to play videos on an external screen. Attachment 77092 http://store.apple.com/1-800-MY-APPL...nplm=MB129LL/A Unlike the OEM Infiniti iPod cable that comes with the Premium Package, it will not charge the iPod while videos (or music) are playing unless you hook up a USB car charger to the USB port on the Apple Composite AV Cable. However, I'd advise you to use this charger with extreme caution since the reviews on the page have said that this plug (as well as the Griffin) would make the unit extremely hot and generate smoke, while possibly having the risk of starting a fire. http://store.apple.com/1-800-MY-APPL...nplm=TN787LL/A Troubleshooting: Problem: Video is in Black & White and you have a newer model iPod Solution: You are using the AV Cable when you need the Composite Cable Problem: The sound is playing but the video doesn’t show at all Solution: Turn on the E-Brake and put the navigation system into the correct AUX mode More information about the new cables:
Originally Posted by likwidfuzion
(Post 2261612)
Here is a full, in-depth explanation of the old and new methods for video output:
http://www.appleinsider.com/articles...th_review.html |
good write up
The question is when can we play video while the car is driving. This is a biggy if someone can hack it...
Originally Posted by G-WIZ KID
(Post 2262746)
Thanks for this, I'll sticky it and if anymore questions arise in this thread or others try and answer them and edit your original post.
do we need to have the navi system for this to work??
Nope, as long as you have the RCA plugs in the armrest you're good to go
3 Attachment(s)
Originally Posted by gmlee86
(Post 2262741)
For the 4G (iPod photo, iPod w/Color Screen) and 5G (iPod Video) models, you can use a commonly-available camcorder video cable. The left cable is correct, but you have to swap the right cable and the video cable for it to work correctly. See the attached pics where I use a Radio Shack camcorder cable to output video from my 5G iPod to the car. Note the cable order in the pic without the RCA plugs in use and look at the order with them plugged in to see how to attach the plugs to get the audio and video to play correctly. |
as long as you have the cable connecters i can watch videos on my non navigation screen?
i have no packages nothing what so ever |
Originally Posted by homelessdrunk
(Post 2266433)
awsome time to go buy an ipod
(Post 2266716)
Originally Posted by bboysteele
(Post 2266736)
The only reason I bought my IPod was because of my G37!
(Post 2266736)
so is it true that the OEM cable can overheat your iPod? any links por favor? |
Originally Posted by chasemyaccord
(Post 2276234)
haha me too. well that and my last one was sorta dying.
