Widest tire size i can fit on my g37x
Check this thread for some wider "square" setups (all wheels/tires same size)
https://www.myg37.com/forums/brakes-...post-here.html
Is your AWD a sedan or coupe, the coupe can handle a bit more aggressive (less positive) offset.
As far as lightweight rims, if you stick with 18s a lot of them are lightweight, if you go to 19s and especially 20s I'd need to know your budget as they get expensive in a hurry as you go up in size and try to keep weight down.
hey guys new to all this ...i was wondering if my 2009 g37x with no mods...can put this dimension of rim on it...17inch Silver BSA Rims with 215/45/17 tires
bolt pattern 5x114.3 et40
center bore 73mm .....and would it look good in your opinion,,,if you know what the better specs would be ...plz let me know...asap ...as i am looking to get rims very soon...thx,,,
Thanks!
i was thinking of 245/45R18 or 245/50R18 or 235/50R18 ?
please help
thanks
I currently have 225/50R18 pilot sport A/s 3+ tires
Do you experience Tampling
I'm running a square setup 20x9 +38 offset with 265/35/20 with no fitment or drivability issues. Is there something that I should be concerned about. This is on my 2013 G37X
