Tire issue
Tire issue
I've been having problems with my rear time leaking in the last month. I filled up air 3 times in 3 weeks. I checked for puncher nothing, broken rim nothing, i've changed the nozzle head. Am i missing something??? your help would be great...
mobe (12-17-2014)
Clearly your wheel has an air leak. If you want to know exactly where it's coming from, remove it and either submerge it in a tank of water and see where the bubbles come from or mix a few ounces of dish soap into a couple of gallons of water and pour it over the tire and see where it makes bubbles. There is your leak.
mobe (12-17-2014)
MYG37.COM Platinum Sponsor
The sensors have gaskets that if disturbed or not replaced, can crack or leak. Hairline cracks in the wheel and corrosion in the wheel's lip at the bead area all common causes. Find an installer than has a dunk tank. Fully submerging the tire/wheel in a tank of water and looking for bubbles is best way.
Digilog
08-17-2015 03:54 PM
