Help with wheel fitment.
Hi, I am considering buying these wheels off someone and need help of they will fit well.
They are off a 2012 Maxima
The bolt pattern is right but its the width that scares me.
Front 20x9.5
Back 20x10.5
Offsets +45
Tire sizes are normal with 20/35/245 and 20/30/275
~~~This is a 09 g37x Sport by the way~~~
Front 20x9.5
Back 20x10.5
Offsets +45
That way you know they fit.
Telcoman
this calculator will clear things up
Your stock G37X Sedan Sport wheels are 18x7.5 +45 on 225/50/18 tires
So entering the old & new data you get
Fronts~extend out 25.4mm so about an inch out from your current setup
Rear~extend out 38.1mm so about an inch and a half out from your current set.
Just measure out from your current setup and see if that's manageable.
Plz help I no this has bin. Over but
I want to get 20x10.5 all around on my 2012 g37x sedan will thy fit and what off set would I need to go for front and rear keep in mind I am looking to get a 2 inch drop dun as well also tier size thanks
