The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old 09-12-2013, 03:41 PM
  #46
DRVRSWNTD
DRVRSWNTD's Avatar
Will 265/35 fit on a 19x9+40 in the front of a '13 6MT sedan? Eyeball says yes, but I have yet to see anyone running it here or G35Driver
I know the 19x9 works as I used to have 245/40s on, but I wanted less stretch and the 265/35 tires were a steal.
Thanks in advance...
Old 09-13-2013, 03:25 PM
  #47
Jethro
Jethro's Avatar
OK guys, I have a 2009 G37xS sedan lowered on Swift springs. I also have a set of 19x8.5 +46mm wheels installed with 245/40-19 tires. The thought occured to me that I might get some spacers in order to help the weak offset of this setup. For the sedan, it seems like a nice flush setup is 20x9 +32 and 20x10.5 +45.
Playing with the calculators, it seems I would need a 20mm spacer in the front and 25mm in rear to come close to those offsets. Does that seem right?
Any concerns with bolt on spacers (H&R DRM) in these sizes? I know I should just get new wheels that are to my liking, but this is a temporary solution.
Thanks!
Old 09-13-2013, 04:15 PM
  #48
DRVRSWNTD
DRVRSWNTD's Avatar
So long as you either use extended lug studs or the spacers come with new lug studs built in, you should be fine.
Thanks!
Jethro (09-15-2013)
Old 09-17-2013, 08:24 PM
  #49
Austink131
Austink131's Avatar
Hey guys,
My friend has a 2013 G37s sedan and about to buy some wheels
There is a set of volks gt30 with these specs:
Front 20" 8 1/2 offsets +42
Back 20" 9 1/2 offsets +37
Would the volks fit his car?
thanks
Old 09-21-2013, 02:00 PM
  #50
joebrez
joebrez's Avatar
I have a 2009 G37X. I am looking to upgrade the rims. I found a local guys selling the staggered setup off of the "S" Sedan.
Using the Calculator:
F:225/50/18
R:245/45/18
Results in a different of .66%. Is this safe for the AWD? I would figure so since it's below the 3% number I've been reading.
Old 09-21-2013, 02:32 PM
  #51
Received 4,941 Likes on 4,174 Posts
F:225/50/18
R:245/45/18
Those will work fine, if you want an even sportier look and a bit more planted ride you can also go 245/45/18 & 275/40/18 that would look and you'll still be below 1% on diameters.
Old 10-03-2013, 04:37 PM
  #52
dv_ous
dv_ous's Avatar
Hopefully this question won't come off as me being lazy about doing my own research. I have and I've gotten so many different answers that I'm not sure which is correct for my situation.
I'm planning on ordering a set of super deep Forgestar F14s, 19x9.5 and 19x10 for my G37S sedan lowered on Swift springs. Will the offset of +30 front and +40 rear give me a flush look without having to do any other modification?
I'm planning on going with 245/40/19 and 275/35/19 tires. Should i got with 255/40/19 for the 19x9.5 wheel for a better fitment?
Thanks.
Old 10-04-2013, 01:48 AM
  #53
Thanks.
It's going to be a tight fit, especially in front. A +35 front would be better IMO, with a mild Swift drop the front inner fender well may not be an issue though. I'd stick w/ the 245s in front w/ that tight clearance.
dv_ous (10-04-2013)
Old 10-04-2013, 03:14 AM
  #54
saparda
saparda's Avatar
alright so i got myself WORK GS4
20x9.5+25
20x10.5+23
not sure why RAV gave me +23 at the back! even though most people here who got GS4 went with +32 , i even asked in the email but no reply? actually sent 2 PM's for updates cuz they are spacial order but no reply??? but anyway, i'm planning to go with 285/30 at the back and 245/35 at the front. i understand that +23 is a bit aggressive,
is there a big difference? will i need spacers at the front or the back for a perfect flush?
Old 10-04-2013, 04:14 AM
  #55
LegitMW
LegitMW's Avatar
20x9.5+25
20x10.5+23
a 285 in the back with that sizing actually has a little poke so you'll need to dial in some camber
Old 10-04-2013, 04:21 AM
  #56
saparda
saparda's Avatar
how much negative are we talking here? what about if i went with 275?
Old 10-08-2013, 11:13 PM
  #57
theART
theART's Avatar
Hey Ladies and Gents,
I got a G37 Coupe Sport and would like to run 20x10 ET35 on the back with 275/35/20 and don't want the rims to stick out from rear quarters, I rather have them little in and adjust with spacers if needed.
So is anyone running 20x10 ET35 on rear and have feedback or a pic? (or 20x10.5 ET41, it's same from outside)
Thanks
Art
PS: Dropped on Eibach Pro
Old 10-09-2013, 12:19 AM
  #58
I would like to run 20x10 ET35 on the back with 275/35/20 and don't want the rims to stick out from rear quarters, I rather have them little in and adjust with spacers if needed.
Thanks
Art
Sedan or Coupe?
Old 10-09-2013, 12:22 AM
  #59
theART
theART's Avatar
Sedan or Coupe?
Thank you for pointing out, it's a Coupe Sport, corrected my org post
I am just so excited to get some new wheels that my mind is somewhere else
Art
PS: I want them to look like this but on coupe, wheel just behind fender/quarter and tires even with wheels.
Old 10-14-2013, 11:21 PM
  #60
darksideG35
darksideG35's Avatar
Have a 2008 g37s coupe that's getting lowered on swift springs, looking at ordering wheels soon but wanted to check offsets and tires before I pull the trigger. Wheels are 19x9.5 +20 and 19x10.5+30 was thinking about running 245/35 and 275/35 tires, will this setup work with those offsets?
Quick Reply: The OFFICIAL "I have a wheel offset / tire fitment question!" thread
