Official~Best offsets for running FAT tires!
Old 03-18-2017, 03:19 PM
  #1201
RJ's_G37
RJ's_G37's Avatar
19x9.5 19x10.5 +40.i should be able to fit this on a sedan on coils right?
Old 03-18-2017, 03:34 PM
  #1202
PNW_IPL
PNW_IPL's Avatar
Decided to pull the 295 off and save them for a different build. Went with a 275 35 instead. With the added room i was able to lower it where i wanted and keep -2.5 camber.
So the specs are now 19x10 +30 275 30 front
19x11 +20 275 35 rear. When the fronts go ill probably run 275 35 19 all around.
Also peeled the dip off lol.
Old 03-18-2017, 03:37 PM
  #1203
Nappy_G
Nappy_G's Avatar
you will most definitely be able to fit it but what tire size are you planning on going with ?
Old 03-18-2017, 03:38 PM
  #1204
Nappy_G
Nappy_G's Avatar
loooks amazing PNW_IPL
Old 03-18-2017, 05:37 PM
  #1205
RJ's_G37
RJ's_G37's Avatar
Im not sure im running a 275 35 right now in the rear..what would you recommend for the front and back?
Old 03-18-2017, 06:58 PM
  #1206
Nappy_G
Nappy_G's Avatar
you should be fine in the rear I'm running 20x10.5 +37 in the rear with a 275/35 and No rubbing
you can probably run a 255/40 up front or a 245/40
Old 03-18-2017, 08:39 PM
  #1207
Received 4,940 Likes on 4,174 Posts
PNW_IPL, looking very nice now!
Old 03-18-2017, 10:19 PM
  #1208
PNW_IPL
PNW_IPL's Avatar
Thank you I appreciate it
  #1209
PNW_IPL
PNW_IPL's Avatar
Thank you botha. I appreciate your help!!
Old 03-19-2017, 08:10 PM
  #1210
VenomGT9
VenomGT9's Avatar
much better
Old 03-19-2017, 08:12 PM
  #1211
PNW_IPL
PNW_IPL's Avatar
Originally Posted by VenomGT9
much better
Thanks Venom
Old 03-21-2017, 08:32 PM
  #1212
VenomGT9
VenomGT9's Avatar
now about those center caps...
Old 03-21-2017, 10:55 PM
  #1213
PNW_IPL
PNW_IPL's Avatar
Theyre in the junk drawer. Gotta bustem out
Old 03-24-2017, 12:20 PM
  #1214
PNW_IPL
PNW_IPL's Avatar
Js for u
Old 03-26-2017, 09:00 PM
  #1215
EuroRSN
EuroRSN's Avatar
^ Amazing!
Guys quick question. I want to run 20x9 with 25 offset in the front on my sedan. I should be okay with 245/35/20 right? I just hate how sunken in the 20x9 35 offset looks.
Quick Reply: Official~Best offsets for running FAT tires!
