Picture Share G Vert Th ultimate forum to view and post high definition pictures of your G Vert.
SPC front camber arms install on the vert!
Old 05-05-2012, 10:59 PM
cereal2k
Mr. Drop it like it's hot
cereal2k's Avatar
I had 3 things done today.
1. Swapped out the front Eibach pro kit springs with the H&R front vert springs.
2. Installed SPC front camber arms.
3. Re-alignment to be within spec for front cambe LHS 0.9 deg, and RHS 1.1 deg.
* added 10WHP also.
Proper photos coming soon. Two meets/shows tomorrow. May is hella busy.
eibach before
Eibach coupe front spring compared to H&R vert front spring
front spc camber arm on the RHS
I added 10 WHP here
Align time.
At first they set it to 2.5 deg -ve camber. I pointed out it's adjustable now, hahaha
Redo of the alignment
Old 05-06-2012, 01:39 AM
SkylineAWD
SkylineAWD's Avatar
Car looks great man. I have my coilovers sitting at home, and my SPC front and rear kit are ordered so I will hopefully be getting it all put in this week. How much did they charge you on alignment?
Old 05-06-2012, 06:58 AM
G37Sam
G37Sam's Avatar
Nice!
Can you post your alignment sheet please
Old 05-07-2012, 01:02 AM
cereal2k
cereal2k's Avatar
Yeah. Quick pic from a mini shoot the day after the drop. I expect more settling andmaybe more low in 2 weeks or so.
New tires also. toyo brand up front. Slightly not as stretched as the falkens.
Old 05-07-2012, 07:32 PM
cereal2k
cereal2k's Avatar
Originally Posted by G37Sam
Nice!
So what's funny is I have an exotic alignment. Add 6% sales tax to that figure. If the suspension is not stock they can charge way above normal. My Dealer charges 84, but I opted to go here. 12 month warranty and free checks and adjustments during the warranty period. So I can take it on the mountains and get a free adjustment each month. The only issue right now is it's pulling to the right LOL.
But my steering wheel may be off center. Each time to go on a mountain run it seems the steering wheel goes slightly off center. Anyway, that's a free dealer adjustment. Just gotta confirm that suspicion. The dealer last did my alignment and steering wheel check before this one.
Old 05-08-2012, 02:06 AM
G37Sam
G37Sam's Avatar
You're at -3 degrees of camber in the rear!
Old 05-08-2012, 08:59 AM
cereal2k
cereal2k's Avatar
since 2010
Jensen Mathew
08-16-2015 08:06 PM
Redfire32
08-11-2015 09:05 AM
kyro840
08-09-2015 01:38 PM
Quick Reply: SPC front camber arms install on the vert!
