25mm H&R spacer at the back, 2 inch drop, not for long
So I tried out a 25mm spacer this week on the vert and I've decided to go down to 20mm. 25mm is just a wee bit aggressive with a 2 inch drop. If ride height adjustability is an option then I've go back to this. 20mm is up front.
here are the cell pics and specs
-2 inch eibach coupe springs drop on the vert
-rear tires 255/40/19 hankook ventus v12
-fender lining already trimmed
- 3 degress negative camber right now. No further adjustability
-rear vert wheel offset is +30
https://www.myg37.com/forums/wheels-...-stock19s.html
Here are the daylight pics with the DSLR
