6 speed launch?
6 speed launch?
Been searching for tips on how to best launch a 6 speed at the drag strip. I've found ideas on rpm, clutch release methods etc.
I was curious how people are holding their car at the light to not break the beam. It might be simple but are you heeling the brake pedal, using the handbrake, or are you just making sure all momentum is gone and letting it sit there with out any aid?
Any insight is much appreciated!
A track SHOULD be flat and you shouldn't need to apply the brakes when launching. After staging (2nd yellow light) start getting the rpm's up. Relax and don't pop the clutch or you will get wheel hop. Easier said than done.....
IDK if this needs to be said, but turn off Traction Control.
You got that right. I've never taken this car to the dragstrip, but when just playing with the car I've found my best launches are the ones where I'm not trying to wring every ounce out of the car.
I figured out to just let it sit there and had no issues with that part.
Traction control off, tried launching at different rpms but either bogged spun bad, or wheelhopped. Still looking for that ideal amount of feathering of the clutch and ideal rpm. I think my best 60' was actually when I bogged to a 2.4!
I'm too young to die!
I can't launch with traction control on anymore... Ever since I put 285s in the rear ( lol ) the car just shuts down no matter what rpm I try and launch at... I'm getting 4.08s in the next week or two whenever they arrive in the mail and then we will see what I need to do.
Don't know how you ever did in the first place. If you come out of the hole as hard as possible with TC on, you'll get slapped back. It's pretty embarrassing. Similarly, if you try to oversteer around a corner without TC, it gets real messy. Sometimes I wish the TC button were right there at the top of the shift ****. That would be cool. Or at the very least, on the side console next to the heated seat *****. Oh well.
I suspect he's riding the clutch, or using his parking brake, or both. Although our parking brake is hardly enough to to do an AT-like brake-stand with... it's just a parking brake, not an actual E-Brake.
Whatever he's doing, I'm sure it's killing his clutch pad. But whatever, it's his car, and one man's abuse in another man's Racecar.
Ive practiced on this car and the sweet spot is 2K. Nothing over 2,000rpm is necessary.
VDC off, rev it to 2K, dump the clutch 80%, feather it at the top for about one full second, as SOON as you feel the tires hook 100%, THATS when you stab the gas pedal.
The #1 biggest mistake is going WOT immediately after you let the clutch up, and thats when you fail miserably and run a 16 second quarter mile.
Be patient and time the gas pedal stab accordingly. You CANNOT launch this car without slipping the clutch for a couple heartbeats.
I'm just now re-learning how to jump out of a dead stop in this car with the RJM Clutch Pedal Assembly.
I have to say, it's a heck of a lot easier now.
^ Sounds about right.
misc
29
05-24-2023 03:57 PM
sunshineskyler
11-13-2015 09:47 AM
