Mods for greater lower end torque + hp
Basically I don't want a bull**** dyno result like the attachment....where I'm not pulling on a stock G37 until the engine really starts producing power (at least 4th gear, ~5300+ RPM).
I do mainly city driving so red lining my car at every light is not something I want to be doing to feel my mods.
This dyno is pulled from Z1 motor sports 400hp package
https://www.z1motorsports.com/z1-pro...ge-p-7223.html
Is the main reason for lower end torque/power loss due to the intake manifold? Could I do a similar set up to my G (minus the intake manifold) and except a relatively flat line dyno (maybe +10 to 30whp across the stock line)?
Proof to support your claims please (either logic or numbers/dynos)
If I said anything that doesn't make sense/needs clarification, call me out son
The VQ37 is milked from the factory for low end torque.
Only way to get more low end is to swap your engine out for a nice V8, or go down the stroked engine route which IMO is a waste of money.
kingdingaling (03-11-2016)
this.
most bolt-ons- will just get you:
1. noise
2. bling
3. empty wallet
i added a axle-back exhaust for ~$250 for a deeper exhaust note and called it done.
the factory intake is a cold air intake, and the filters are ridiculously easy to replace. i may get some washable R2C panel filters when its time to replace the factory filters.
1. noise
2. bling
3. empty wallet
I did purchase K&N typhoon air intake system and they gave me a dyno sheet of a VQ engine from an 09 Z. It gave roughly 5-14 ft/lbs torque gains across the spectrum and anywhere from like 3-15 hp gain across the entire spectrum (4th gear). I did not feel a difference after install though. It sounded way cooler. Maybe the heat shields aren't as affected as you'd think?
you lost bro? :P
no thanks.
Im looking at getting the 400hp package from Z1 to give the car a little more oomph. I dont want to go FI or do any major work on the engine. Anyone on here actually have this package installed on their G?
For me personally, it doesn't make sense to use it. I don't hit over 5k rpm terribly often (maybe 2x every time to and form work 20 mins of driving)...and when I do, I'm not above it for long.
Well I am rethinking my mod choices. Right now its looking like a Z1 plenum, FI RHFC, and R2C CAI (have some generic garbage CAI right now). Any idea how much headers would add to that setup? Many people say the headers aren't worth the expense but I have yet to find an isolated comparison of a setup with and without headers. Oh, I also have a ARK CBE currently installed (love the sound).
Sounds a bit too $$$ for my blood
