Rear Mount Turbo
[QUOTE=MyocyteX;3132779]Squires Turbo Systems - Nissan 370Z
When I think rear mount turbo, I think cheap and lazy. Most people here feel the sam I'm sure so be prepared to get flamed, but I think you should do it if you want to. I would be interested to see it in action.
Good luck.[/Qoute]
I don't think cheap and lazy should go along with a rear mount system, a lot of z's do ir to save space or other cars do it because space is tight.
Good luck.[/Qoute]
I come from the Corvette world and over there everyone hates the STS kits. They do have more lag than the typical front mounted turbo kits because of the longer charge pipes involved. That is turbo basics 101.. Longer charge pipes take more time to pressurize. Besides the longer charge piping you also have to remember the exhaust gas hitting the rear mounted turbo is cooler than it is at the front of the car and that is energy lost.
Also, the oil scavengers are usually the first thing to fail in the STS turbo kits. So be prepared to replace the oil scavengers that come in their kits almost immediately.
And finally the more charge piping you have the more fun you will have troubleshooting a boost leak
My kit made more power per pound of boost then the gym kit. Some people are so miss-informed because the people with the deepest pockets have the biggest mouths.
rolltidealumni (11-02-2016)
BUMP... I've been contemplating a rear mounted setup and want to hear some first hand advice/stories. If you don't personally know someone with dyno graph proof, a link to a build thread or installed it themselves, please don't respond. I don't care what you think you've heard about lag, STS, cheap/lazy etc etc.. Opinions wont help me, help you, get this done.
Hey man look up papasmurf370 on instagram, he did one successfully. I think he is on the 370z forums too. I was thinking of doing this...especially now that Comp Turbo makes the oil-less triple ceramic turbos...which is what papasmurf is using on his Z. It's a grease packed bearing, that you grease every 3k-5k mile, or basically every oil change. Check it out, it's not a hard set-up and can be done for just under $4K. He has a youtube vid too
Majeed Bader
09-04-2015 01:55 PM
nethole
08-12-2015 04:08 PM
JakeG37
08-03-2015 09:28 PM
