MEDIA SHARE Intake, Exhaust, Engine, Forced-Induction & Drivetrain
Help Does a lightweight flywheel make your G37s faster?
Old 01-13-2009, 03:22 PM
  #31
gtracing
gtracing's Avatar
Originally Posted by G37Sam
good luck driving uphill with a light clutch & flywheel.. expect to stall with every gearshift lol IMO unless you're going to track your car these should be last on your mod list
it's actually not THAT bad to drive uphill from a stop...that's what ur ebrakes for...i found that rushhour traffic was the worst...especially with a heavy *** clutch
Old 01-13-2009, 03:57 PM
  #32
Mike
Mike's Avatar
+1 for proper technique
What kind of clutch did you have?
Old 01-13-2009, 08:02 PM
  #33
gtracing
gtracing's Avatar
Exedy stage 2 clutch and exedy flywheel...
used it for 3 months, then removed and sold it
Old 01-13-2009, 08:05 PM
  #34
VIP G
VIP G's Avatar
says the guy with the autotragic...
I have no problem at with both of these upgraded
Old 01-13-2009, 08:15 PM
  #35
Mike
Mike's Avatar
+1 You do have to make an adjustment however
Old 01-20-2009, 01:49 AM
  #36
G37Sambanks
G37Sambanks's Avatar
I think it is a great idea for me to drive a g35,g37, or 350z with a lightweight flywheel and performance clutch setup to see if that is really what i want. Maybe i can talk to sharif and see if he knows someone. You guys are a lot of help. Thanks
Old 04-20-2009, 09:40 PM
  #37
JamesEVO
JamesEVO's Avatar
Ok my friend has a 00' Eclipse and my friend said putting a new flywheel and transmission would make his car perform better would it be the best decision and the cheapest one?
Old 06-10-2009, 02:13 AM
  #38
DownstairsDave
DownstairsDave's Avatar
A new transmission ? Oh yeah, those things are cheap. Like 50 bucks...
Old 02-10-2014, 02:46 PM
  #39
TheradicalO
TheradicalO's Avatar
More like three fity
Old 02-10-2014, 04:26 PM
  #40
M3ng
M3ng's Avatar
I am 29yrs with competition light flywheel and stage2 clutch on my 08' coupe. It took some time getting used. Although I live in suburbs of chicago, rush hour for me is not that bad to and from work(45min drive). BUT if you live in an area with heavy rush hr. traffic, it will get very annoying. After a while, atleast for me since it is my daily, I dont even notice it. It makes it a little fun rev matching more.
Old 12-12-2014, 10:21 PM
  #41
Blade89
Blade89's Avatar
Just to add to this since it seems like I'm one of the few that has this installed (a few months too late). My slave cylinder blew 4 months ago and took the flywheel and clutch with it. The Stillen lightweight flywheel and clutch package was the same cost as the dealer quoted me for just replacing it with stock, so I decided to do it.
It downshifts WAY faster when you're rev matching. It feels a LITTLE faster, but not by a whole lot. The chatter from the transmission while in neutral with the clutch out is a little annoying (kinda sounds like a diesel engine at idle), but not too bad.
All these people that claim it is harder to drive...are only a little correct if you know what you are doing. I've stalled it more in the last 4 months than I have in the last 3 years, but it's only in like parking lots or other very slow maneuvering. Rush hour traffic is still fine, uphill starts are still fine. Then again I would heel-toe the engine on hills before, so that helped the transition.
Old 12-13-2014, 11:06 AM
  #42
slartibartfast
slartibartfast's Avatar
Lighter wheels have much greater effect on acceleration than flywheel, and that has greater effect than pulleys. The farther weight lies from the axis of rotation, the stronger the inertial effect. Not only are tires and wheels larger in diameter than a flywheel, there are four of them vs the one flywheel.
Start at your wheels if you want more acceleration. If you've already achieved that goal, then yes, lighter flywheel. It didn't make that much of change in drivability on my Miata but I didn't get the lightest available because it's a street car.
Mattlorentzoe
05-24-2021 08:49 PM
Kuro
12-12-2015 02:39 AM
BANNISTER
12-10-2015 04:14 PM
Kuro
08-15-2015 04:33 PM
Slayer7435
08-09-2015 07:33 PM
Quick Reply: Help Does a lightweight flywheel make your G37s faster?
