Help Does a lightweight flywheel make your G37s faster?
newbs...
a flywheel will not increase your hp....it will incrase your acceleration due to a lighter rotating mass...but ur engine still produces the same power...
does changing your wheels increase your hp? it doesn't! your car feels like it's accelerating faster because you have lighter rims...same idea with the flywheel...
for the even newer newbs...no, the clutch will not increase hp either, same goes with nismo stickers...
the car will feel a lot quicker during acceleration, which is a good thing, but the car is now 10x harder to drive. You'll need to rev the rpm's higher to launch, and you'll need to shift a lot quicker....
i changed my flywheel/clutch on my old car...after 3 months, i swapped back to oem...
think about rush hour traffic....
newbs...
Light Flywheel/clutch/rims/tires/brakes do not increase engine output.
They do, technically, increase horsepower put to the ground (more technically, they decrease drivetrain loss).
The following 3 users liked this post by Mike:
The impact of wheels/tires is FAR greater than the impact of a flywheel clutch.
Losing 10 lbs of unspring weight on a ring, vs losing 10 lbs unsprung weight on a disk.
Remember, the diameter of the tires (ring) is far greater than a flywheel and clutch (disk), and that a ring has more inertia than a disk.
I don't remember the equations to calculate... but I do believe it is an exponential equation.
the whp which is increased by reducing the weight of the flywheel is not by much....but you do feel the car accelerate a lot faster...
at the end of the day, really consider if you wanna change your flywheel...cause it's a bitch to drive especially if it's your daily driver
so you're saying that a 2whp gain makes the car feel like it is accelerating a lot faster?
It will definately rev faster (and drop the revs faster too), but IMO, an intake would have a much more noticeable effect, and the intakes arn't proven to provide much if any gain...
I totally agree on reconsidering the flywheel, as you will hurt your daily driveability, and it isn't cheap to go back once you do it.
AcezG37 (12-06-2018)
This is why I am glad Sharif told me about this site. You guys have been a lot of help. I am still on the fence about the mod, but I now have a greater understanding of the mod and what it really does and does not do. The car cost me so much, I need to get as many daily driven miles out of it as possible. I want to build a track car and keep my g37s as my #1. I think with everything you people have said, I am going to wait and just do the lightweight flywheel and performance clutch on the track car.
Pullys on the Civic make a rather signficant difference as well, whereas on the G's, pully's make no measurable difference
On the flip side, once you make the adjustment, a lightweight flywheel will be driveable. I think of mine as a sort of anti-theft feature... everyone stalls my car between the heavier pedal, 8 lb flywheel, and stickier clutch disk
The major difference is unless I'm shifting rather quickly, I actually have to keep my foot on the gas to keep the revs up.
If at all possible, find someone with your potential future setup and drive their car before committing. There WILL be additional noise (sometimes significantly more noise) with an aftermarket setup.
Sam Rothstein
going from 85whp to 90whp is a much more significant gain than going from 270whp to 272whp
#29
good luck driving uphill with a light clutch & flywheel.. expect to stall with every gearshift lol IMO unless you're going to track your car these should be last on your mod list
#30
at the end of the day, i still believe it's not worth it...especially pulleys cause it doesn't do any short term damage, but it definitely wrecks the motor in the long run...
