FS: Fog Light LED Bulbs! SMD and Hi-Power LED. Upgrade your lights!
Old 09-20-2012, 04:50 PM
  #46
brainpa
brainpa's Avatar
OK, so after doing some research, I would like DD's opinions.
H1 HID fogs or The bright LED fogs?
Old 09-20-2012, 05:05 PM
  #47
Diode Dynamics
Diode Dynamics's Avatar
If you are looking more for looks with simple install, go with the bright led fogs!
If you are looking more for function, then I'd go with the H1 Hid fogs.
-Emily
Old 10-06-2012, 12:35 PM
  #48
Diode Dynamics
Please feel free to post questions or comments!
Old 10-06-2012, 01:54 PM
  #49
1BAD2012IPL
1BAD2012IPL's Avatar
Just ordered mine will post pick when I get them installed
Old 10-06-2012, 03:08 PM
  #50
Diode Dynamics
Awesome!
I can't wait to see your Pics.
If you need any help or need questions answered. We're always here for you, just one phone call away.
-Garrick
Old 10-25-2012, 10:38 PM
  #51
SteveG37
SteveG37's Avatar
DD, did u confirm the fitament on these H1 bulbs on 08G37S? How bout pics?
Old 10-26-2012, 07:06 PM
  #52
Diode Dynamics
H1 has been test fitted on this model car however if you are having issues. slight modification may be required.
-Garrick
Old 10-27-2012, 04:21 PM
  #53
SteveG37
SteveG37's Avatar
-Garrick
When u say "slight modification may be required" could you please explain exactly what that means? What kind of modification and how difficult etc.
Thanks!
Old 10-28-2012, 11:15 AM
  #54
Diode Dynamics
Sorry for the confusion. We have in the past run into a few cases where the customer had to take a utility knife or a file and shave off a millimeter of plastic from one of the pegs so that the socket will line up correctly. Its nothing major and on a difficulty level of 0 - 10, this would be a 2. And again I enforce this has only happened to a few people. The vast majority H1 bulbs we sell fit in perfectly.
-Garrick
Old 11-14-2012, 03:38 PM
  #55
Only4theGnme
Only4theGnme's Avatar
Thanks!
I had the exact same issue when mines came in SteveG37...did you make the mod to the housing to get them to fit? I'm debating if I want to do that.
Old 01-21-2013, 10:10 PM
  #56
vince22sh
vince22sh's Avatar
interested on 6K Fog light LED bulbs for 2009 g37S but link on first page dont work ..
Old 01-22-2013, 03:37 PM
  #57
Diode Dynamics
Sorry about the links are now working to the LED fog lights (above)
Here is a working link for the 6000k HID fog light bulbs: 2009 Infiniti G37 Sedan Fog Light HID Conversion Kit
Michelle
DD
Old 01-28-2013, 12:24 AM
  #58
SPN27RU
SPN27RU's Avatar
how did you insert the lamp to foglight? I could not because hole in a headlight, less than the diameter of the lamp.
Old 01-28-2013, 10:11 AM
  #59
Diode Dynamics
On most H1 applications (such as some models of G37, you must slightly trim the socket in order to place the bulb in. This is just because of the tiny size of the original H1. All you have to do is notch one small corner, which does not affect any functionality or the fitment of the original bulb.
Thanks!
Paul
Old 02-28-2013, 01:50 PM
  #60
myk1013
myk1013's Avatar
whats the brightest LED bulbs I can put as my city lights? Do you have any pics??
Quick Reply: FS: Fog Light LED Bulbs! SMD and Hi-Power LED. Upgrade your lights!
