Special New FREE Car Care Product every week at DetailedImage.com
New Weekly Special At Detailed Image
This week through 1/4/2011 (EST) you can get the DI Accessories Gentle Fine Grade Clay 100g for free with a purchase over $30 (no including s/h or tax). You don't need to add this item to your cart, just use the coupon code WSGENTL5210 to automatically get this free item (limit one coupon code per order).
100 g Regular Price $10.99
Let me know if you have any questions.
- Safely and effectively remove tar, sap, paint over spray and more
- Fine grade clay bars will not mar your finish when used properly
- We recommend using Dodo Juice Born Slippy as your clay lube
This week through 1/11/2011 (EST) you can get the DI Accessories E-Z Detail Brush for free with a purchase over $90 (no including s/h or tax). You don't need to add this item to
your cart, just use the coupon code WSEZDET0111 to automatically get this free item (limit one coupon code per order).
Mini Size Price $14.99
- Mentioned as an essential tool professionals use in Autoweek magazine
- The professionals choice for a wheel brush to clean the inner barrels of your wheels
- Works great with soap and water for maintaining wheels or with a wheel cleaner for heavier cleaning
- Turns a good wheel detail into an exceptional one that really shines with open spoke wheel designs
- Can also be used in your engine bay to agitate contamination after degreasing
This week's Weekly Special is Poorboy's World Wheel Sealant - 8 oz.
Use Coupon Code WSWHEEL0311 to receive it for Free. A $19.99 value! Min spend $80. Offer ends 1/25/11 at 11:59 PM EST.
- Properly protect any wheel finish and minimize the amount of brake dust and road contamination
- Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
- One jar will last dozens of applications when applied correctly. The thinner the coat the better.
- Cleans, restores, protects and enhances gloss all in one simple step.
- Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
- Apply with a foam applicator pad and remove with a clean microfiber towel
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt.
Use Coupon Code WSSHEEP0411 to receive it for Free. A $9.99 value! Min spend $45. Offer ends 2/1/11 at 11:59 PM EST.
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
This week's Weekly Special is DI Accessories Ultra Fine Clay Bar - 200 g.
Use Coupon Code WSULTRA0611 to receive it for Free. A $18.99 value! Min spend $55. Offer ends 2/15/11 at 11:59 PM EST.
- Our finest grade clay bar to ensure minimal marring or swirls added
- Perfect clay bar for those who regularly maintain their vehicles
- We recommend using <a href="http://www.detailedimage.com/Dodo-Juice-M35/Born-Slippy-Clay-Bar-Lube-P326/250-ml-S1/">Dodo Juice Born Slippy</a> as your clay lube
This week's Weekly Special is Meguiar's Ultra Finishing Polish M205 - 32 oz.
Use Coupon Code WSULTRA0711 to receive it for Free. A $27.99 value! Min spend $165. Offer ends 2/22/11 at 11:59 PM EST.
- Removes swirls and light imperfections on any type of paint
- Finishes down haze, hologram and marring free
- Perfect follow up to Meguiar's Ultra Cut Compound 105
- Commonly used with a white polishing pad or a black finishing pad
This week's Weekly Special is Leatherique Prestine Clean - 16 oz.
Use Coupon Code WSPREST0811 to receive it for Free. A $19.99 value! Min spend $150. Offer ends 3/1/11 at 11:59 PM EST.
- Detailed Image's best leather cleaner with light conditioners, perfect for maintaining leather
- Restores oils and proteins that are naturally found in leather for a soft and supple feel
- Cleans to a like new, matte finish that has no greasy or oily feel like other products
- Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and buff dry
- We recommend using a terry cloth application pad to help agitate the leather surface
- For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
This week's Weekly Special is DI Accessories Ultra Fine Clay Bar - 100 g.
Use Coupon Code WSULTRA0911 to receive it for Free. A $10.99 value! Min spend $30. Offer ends 3/8/11 at 11:59 PM EST.
This week's Weekly Special is Chemical Guys Citrus Wash Wheel & Rim Cleaner .
Use Coupon Code WSCITRU1011 to receive it for Free. A $8.99 value! Min spend $45. Offer ends 3/15/11 at 11:59 PM EST.
- Citrus based wheel cleaner that is safe to use on virtually any wheel surface
- Concentrated solution makes this a great value as you can dilute it down 7:1 with water
- Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
- Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS1111 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 3/22/11 at 11:59 PM EST.
- An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
- Leaves behind a beautiful matte finish that is not greasy, shiny or oily
- Treated surfaces resist dust, soiling, staining and also repel water
- Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
- Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
- For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 32 oz.
Use Coupon Code WSULTRA1211 to receive it for Free. A $26.99 value! Min spend $140. Offer ends 3/29/11 at 11:59 PM EST.
- Very effective at cutting through deeper imperfections
- Finishes down nicely, but we still recommend a finishing polish after 105
- Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
This week's Weekly Special is P21S Gel Wheel Cleaner - 500 ml Kit.
Use Coupon Code WSGELWH1311 to receive it for Free. A $17.99 value! Min spend $145. Offer ends 4/5/11 at 11:59 PM EST.
- One of the safest, most effective, pH balanced wheel cleaners on the market
- Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
- Perfect option for after market wheels as it is safe for virtually any wheel surface
- Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
- Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 8 oz.
Use Coupon Code WSULTRA1411 to receive it for Free. A $9.49 value! Min spend $50. Offer ends 4/12/11 at 11:59 PM EST.
