Special New FREE Car Care Product every week at DetailedImage.com
#46
This week's Weekly Special is DI Brushes Lambs Wool Duster.
Use Coupon Code WSLAMBS4511 to receive it for Free. A $11.99 value! Min spend $25. Offer ends 11/15/11 at 11:59 PM EST.
- Click product for complete description
#47
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 32 oz.
Use Coupon Code WSULTRA4611 to receive it for Free. A $26.99 value! Min spend $225. Offer ends 11/22/11 at 11:59 PM EST.
- Very effective at cutting through deeper imperfections
- Finishes down nicely, but we still recommend a finishing polish after 105
- Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
#48
This week's Weekly Special is Einszett 1Z Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP4711 to receive it for Free. A $10.99 value! Min spend $60. Offer ends 11/29/11 at 11:59 PM EST.
- One of the best interior cleaners and protectants that leaves your finish factory new
- Easy to get streak free results every time, great scent, and UV protects
- Best used on your dash, gauge cluster, navigation screens, audio components, shift *****, arm rests, leatherette, steering wheels and much more
#49
This week's Weekly Special is P21S Total Auto Wash - 1000ml Refill.
Use Coupon Code WSTOTAL4811 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 12/6/11 at 11:59 PM EST.
- One of the most versatile products we offer, degrease nearly any surface safely and effectively
- Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
- Can be used at full strength or diluted down to clean more delicate surfaces
- Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
- A must have any detailing enthusiasts or pro detailers arsenal of products
#50
This week's Weekly Special is Menzerna Super Intensive Polish SI 1500 (PO83) .
Use Coupon Code WSSUPER4911 to receive it for Free. A $29.99 value! Min spend $185. Offer ends 12/13/11 at 11:59 PM EST.
- Most noted for its ability to easily remove imperfections, good work time, easy removal process and brilliant finish
- You will instantly notice more gloss and depth with just one application
- Can be applied by hand but optimal results are with a buffer and an Orange or Cyan Light Cutting Pad from Lake Country
- A premium medium to heavy cutting polish removing visible surface imperfections while finishing down remarkably well
#51
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL5011 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 12/20/11 at 11:59 PM EST.
#52
This week's Weekly Special is Meguiar's Professional Masking Tape - 1.5.
Use Coupon Code WSPROFE5111 to receive it for Free. A $4.50 value! Min spend $25. Offer ends 12/27/11 at 11:59 PM EST.
- Properly protect trim, emblems, lights, adjacent panels and more when polishing or using a buffer
- Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
- Perfect for protecting clear bra edges so you don't get product build up that shows
#53
This week's Weekly Special is Chemical Guys Black on Black - 11 oz.
Use Coupon Code WSBLACK5211 to receive it for Free. A $12.99 value! Min spend $50. Offer ends 1/3/12 at 11:59 PM EST.
- One of the most unique trim restorers that turns faded trim back to a deep factory black finish
- Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
- Formerly referred to as Chemical Guys Fade 2 Black
#54
This week's Weekly Special is Chemical Guys Extreme EZ-Creme Glaze with Acrylic.
Use Coupon Code WSEXTRE0212 to receive it for Free. A $16.99 value! Min spend $80. Offer ends 1/17/12 at 11:59 PM EST.
- The perfect prep step before applying a sealant to enhance the gloss and depth of any color paint, while hiding minor imperfections
- The acrylic based formula makes it compatible with both sealants and waxes
- Best applied with a foam applicator pad as thin as possible and removed with a microfiber towel
- When using a buffer, best applied with a black finishing pad
#55
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS0312 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 1/24/12 at 11:59 PM EST.
- An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
- Leaves behind a beautiful matte finish that is not greasy, shiny or oily
- Treated surfaces resist dust, soiling, staining and also repel water
- Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
- Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
- For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
#56
This week's Weekly Special is SONAX Glass Cleaner - 500 ml.
Use Coupon Code WSGLASS0412 to receive it for Free. A $12.99 value! Min spend $95. Offer ends 1/31/12 at 11:59 PM EST.
- Highly effective glass cleaner!
- Works great inside and outside of the vehicle
- Engineered by Germany's best from SONAX headquarters
- Gentle and environmentally responsible formula
#57
This week's Weekly Special is DI Microfiber Car Wash Mitt.
Use Coupon Code WSCARWA0512 to receive it for Free. A $3.99 value! Min spend $10. Offer ends 2/7/12 at 11:59 PM EST.
- Excellent wash mitt that is soft and paint safe
- Very cost effective washing medium
- Can be machine washed and dried afterward
#58
This week's Weekly Special is Dodo Juice Born Slippy Clay Lube Concentrate - 250.
Use Coupon Code WSBORNS0612 to receive it for Free. A $12.99 value! Min spend $65. Offer ends 2/14/12 at 11:59 PM EST.
- Ultra concentrated solution makes for over 2.5 liters of clay lube
- Dilute up to a 10:1 ratio with water while remaining super slick
- Wipes away streak free and is safe for nearly any surface
- We recommend picking up a 22oz spray bottle for proper dilution
#59
This week's Weekly Special is DI Brushes Leather and Vinyl Scrub Brush.
Use Coupon Code WSLEATH0812 to receive it for Free. A $3.99 value! Min spend $15. Offer ends 2/28/12 at 11:59 PM EST.
- Outstanding leather care brush to deep clean leather!
- Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
- Soft and gentle leather brush that works great
#60
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt with thumb.
Use Coupon Code WSSHEEP0912 to receive it for Free. A $10.99 value! Min spend $70. Offer ends 3/6/12 at 11:59 PM EST.
- Natural fibers create a super soft wash medium to help minimize the possibility adding swirls and other imperfections
- Incredibly soft fibers break up contaminants and release the contaminants
- Free flowing water rinses the mitt clean, wring it out and hang dry with leather loop
- One size fits all design makes it perfect for a small to extra large size hand
