Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
#1411
Today's Daily special (February 27, 2017) is CarPro Cquartz Applicator.
Regular Price is $2.25. Today's price is $1.80!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Great replacement applicator pad that is included with many CarPro products!
- Two sided: stiff orange foam on one and a grey ultra-soft foam on the other
- Pair it with the CarPro Suede Microfiber Cloths for easy and even application of your favorite coatings!
#1412
Today's Daily special (February 28, 2017) is Meguiar's Ultra-Cut Compound M105.
Regular Price for 32 oz is $27.99. Today's price is $23.17!
Regular Price for 128 oz is $84.99. Today's price is $69.88!
Regular Price for 8 oz is $10.99. Today's price is $7.92!
- Very effective polish at cutting through deeper imperfections
- Finishes down nicely, but we still recommend a finishing polish after 105
- Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
#1413
Today's Daily special (March 1, 2017) is Gyeon Smoothie.
Regular Price is $24.99. Today's price is $18.24!
- Reduce the risk of washing induced marring with this mitt!
- Thousands of soft fibers trap dirt and grime for easy removal
- Elastic cuff helps mitt stay in place during the wash process
- Works great with the Gyeon Bathe shampoo
#1414
Today's Daily special (March 2, 2017) is DI Brushes Paint Brush Style Detail Brush.
Regular Price is $3.99. Today's price is $2.76!
- Easily remove wax and polish residue from from trim and tight spaces
- 7" long brush allows you to access hard to reach areas
- Soft and gentle horse hair bristles makes it a safe brush too!
#1415
Today's Daily special (March 3, 2017) is DI Accessories Bug Sponge.
Regular Price is $2.99. Today's price is $1.81!
- Remove dirt, grime, bug splatter, and more
- High quality, soft, durable foam
- Easily rinses clean
#1416
Today's Daily special (March 6, 2017) is DI Accessories Funnel.
Regular Price is $3.99. Today's price is $2.55!
- Reduces spills when pouring
- Wash and reuse! Extremely durable material
- Makes it easy to dilute concentrated products
- Strong polypropylene stands up to strong detailing chemicals
- Concentrated products are the best value, use the funnel to help dilute them in to smaller bottles
#1417
Today's Daily special (March 7, 2017) is DI Microfiber Glass Polishing Towel (Blue).
Regular Price for 16" x 16" is $5.99. Today's price is $3.24!
- The ideal solution for achieving that streak free finish when caring for glass
- Use a slow wiping motion, while applying some pressure to the glass polishing towel
- The low, ultra thin nap ensures that there is no lint left behind on glass
- Ideally, use a separate towel to apply your favorite glass cleaner and initially wipe dry
- Always wash your microfiber products prior to first use and remove tags to ensure paint safe
- 240 GSM
#1418
Today's Daily special (March 8, 2017) is Meguiar's Unigrit 3000 Foam Finishing Disc.
Regular Price for 6" is $8.99. Today's price is $6.08!
- Safely and easily remove deeper scratches and imperfections from your paint
- Spray the surface with water for lubrication
- Clean the pad frequently with water while sanding
- Start with the less aggressive pads and move up as needed
#1419
Today's Daily special (March 9, 2017) is DI Brushes Pet Hair Removal Brush.
Regular Price is $4.99. Today's price is $3.20!
- Easily remove pesky pet hair from your interior carpets and upholstery
- Rubber bristles use static electricity to attract and collect pet hair
- Great for removing hair from furniture and carpets in your home too!
- Handle can be used as a squeegee to remove water from windows
#1420
Today's Daily special (March 10, 2017) is DI Accessories Razor Blade.
Regular Price for 100 pack is $6.99. Today's price is $4.55!
- 100 pack is an awesome value!
- Fits all standard razor blade holders
- Made in USA high carbon steel
- Quickly remove contamination, stickers, etc.
- Single edged design
#1421
Today's Daily special (March 13, 2017) is Dodo Juice Born Slippy Clay Lube Concentrate.
Regular Price for 250 ml is $15.99. Today's price is $8.93!
- Ultra concentrated solution makes for over 2.5 liters of clay lube
- Dilute up to a 10:1 ratio with water while remaining super slick
- Wipes away streak free and is safe for nearly any surface
- We recommend picking up a 22oz spray bottle for proper dilution
#1422
Today's Daily special (March 14, 2017) is Lake Country Glass Polishing Disc.
Regular Price for 2.25" is $3.99. Today's price is $2.39!
Regular Price for 3" is $4.99. Today's price is $2.84!
Regular Price for 5" is $5.99. Today's price is $3.66!
Regular Price for 6" is $6.99. Today's price is $4.24!
- Polishing away ultra fine scratches, watermarks and other imperfections in your glass
- Can be used on rotary or dual action polishers
- Produces low heat for better results and durability
- Hook and loop backing for easy fastening
- Pair with the CarPro Ceriglass Glass Polish
#1423
Today's Daily special (March 15, 2017) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.08!
Regular Price for 32 oz is $19.99. Today's price is $13.99!
Regular Price for 128 oz is $57.99. Today's price is $41.01!
Regular Price for 10 oz is $7.99. Today's price is $5.74!
- An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
- Leaves behind a beautiful matte finish that is not greasy, shiny or oily
- Treated surfaces resist dust, soiling, staining and also repel water
- Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
- Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
- For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
#1424
Today's Daily special (March 16, 2017) is DI Accessories The Ice Master.
Regular Price is $19.99. Today's price is $14.60!
- Remove ice from your windshield safely and easily
- Polycarbonate resin build for maxim durability
- Annealed brass blade removes ice without scratching
- 2 sturdy deployable arms add 4 scraping options
- Also available in the DI Accessories Ice Master Jr.
#1425
Today's Daily special (March 17, 2017) is DI Accessories Under Armour Detailer Hoodie.
Regular Price for Small is $49.99. Today's price is $40.03!
Regular Price for Medium is $49.99. Today's price is $42.73!
Regular Price for Large is $49.99. Today's price is $42.78!
Regular Price for X-Large is $49.99. Today's price is $42.84!
Regular Price for XX-Large is $49.99. Today's price is $42.87!
Regular Price for XXX-Large is $49.99. Today's price is $45.54!
- Represent yourself as a DETAILER everywhere you go!
- Stay warm and detail in style during colder months
- Loose fit style for comfort
- Under Armour 80/20 cotton polyester blend
- Also available as a t-shirt!
