Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Old 02-27-2011, 07:56 PM
  #46
Detailed Image
Auto Detailing Expert
Detailed Image's Avatar
Today's Daily special (February 27, 2011) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $19.99. Today's price is $14.79!
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Easily clean and maintain your wheels to a like new condition when protected with Wheel Sealant
  • One jar will last dozens of applications when applied correctly. The thinner the coat the better.
  • Cleans, restores, protects and enhances gloss all in one simple step.
  • Very easy to apply and remove. Once removed, the surface of your wheels is very slick.
  • Apply with a foam applicator pad and remove with a clean microfiber towel
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old 02-28-2011, 07:09 AM
  #47
Detailed Image
Today's Daily special (February 28, 2011) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.31!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old 03-01-2011, 08:00 AM
  #48
Detailed Image
Today's Daily special (March 1, 2011) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.39!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
  • Our softest foam pad, the blue fine finishing pad, designed to apply sealants and liquid waxes
  • Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
  • Jet Seal 109 is one of the most popular sealants to apply with a blue pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old 03-02-2011, 08:05 AM
  #49
Detailed Image
Today's Daily special (March 2, 2011) is P21S Total Auto Wash.
Regular Price for 1000 ml Kit is $16.99. Today's price is $13.81!
Regular Price for 5000 ml is $64.99. Today's price is $46.79!
  • One of the most versatile products we offer, degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
Old 03-03-2011, 08:21 AM
  #50
Detailed Image
Today's Daily special (March 3, 2011) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 15" is $8.99. Today's price is $6.56!
  • Thickest, softest, most plush towel we carry.
  • Over 3x thicker than regular microfiber towels.
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
Old 03-04-2011, 08:02 AM
  #51
Detailed Image
Today's Daily special (March 4, 2011) is Lake Country White Polishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
  • A polishing pad designed to remove minor surface imperfections with an abrasive polish on a buffer
  • Menzerna PO106FF polish is one of the most popular products to use with the white pad
Old 03-06-2011, 03:55 PM
  #52
Detailed Image
Today's Daily special (March 6, 2011) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.75!
Regular Price for 5.5 inch is $9.99. Today's price is $7.39!
Regular Price for 4 inch is $5.99. Today's price is $4.43!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
Old 03-07-2011, 08:18 AM
  #53
Detailed Image
Today's Daily special (March 7, 2011) is Meguiar's PlastX Clear Plastic Cleaner and Polish.
Regular Price for 10 oz is $7.99. Today's price is $5.83!
  • Ideal for use on headlights, tail lights, motorcycle windshields, convertible windows and much more
  • Restore clarity to clear plastics by removing stains and imperfections
  • Leaves behind a polymer protection for easier maintenance
Old 03-09-2011, 08:15 AM
  #54
Detailed Image
Today's Daily special (March 9, 2011) is Meguiar's Ultra Finishing Polish M205.
Regular Price for 32 oz is $27.99. Today's price is $19.87!
Regular Price for 128 oz is $84.99. Today's price is $60.34!
Regular Price for 8 oz is $9.49. Today's price is $6.93!
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
Old 03-10-2011, 07:58 AM
  #55
Detailed Image
Today's Daily special (March 10, 2011) is Meguiar's NXT Tech Wax 2.0.
Regular Price for 18 oz is $17.99. Today's price is $13.31!
  • Hydrophobic technology provides relentless water beading and protection against oxidation, corrosion, and UV rays
  • Applies easily with included foam applicator pad
  • Enhances gloss and depth while removing very light surface imperfections
Old 03-11-2011, 08:03 AM
  #56
Detailed Image
Today's Daily special (March 11, 2011) is DI Accessories Gentle Fine Grade Clay.
Regular Price for 200 g is $18.99. Today's price is $13.48!
Regular Price for 100 g is $10.99. Today's price is $7.91!
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
Old 03-13-2011, 01:25 PM
  #57
Detailed Image
Today's Daily special (March 13, 2011) is Chemical Guys M-Seal.
Regular Price for 16 oz is $19.99. Today's price is $14.59!
  • One of the best bang for the buck, pure sealants for under $20
  • Easy to apply and remove when applied properly, which is as thin as possible
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Old 03-14-2011, 07:06 AM
  #58
Detailed Image
Today's Daily special (March 14, 2011) is DI Accessories Leather and Vinyl Scrub Brush.
Regular Price is $3.49. Today's price is $2.58!
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Old 03-16-2011, 08:10 AM
  #59
Detailed Image
Today's Daily special (March 16, 2011) is Optimum Instant Detailer & Gloss Enhancer.
Regular Price for 17 oz is $9.99. Today's price is $7.19!
Regular Price for 32 oz is $17.99. Today's price is $13.54!
Regular Price for 128 oz is $49.99. Today's price is $39.27!
  • An outstanding quick detailer that enhances gloss and depth while increasing surface slickness
  • Easy to apply and remove streak free by misting into a plush microfiber towel and wiping your paint
  • Most commonly used after washing and drying your vehicle as a maintenance product
  • The 32oz and 128oz sizes are concentrated formulas to get even more bang for your buck
Old 03-18-2011, 08:05 AM
  #60
Detailed Image
Today's Daily special (March 18, 2011) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.45!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Quick Reply: Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
