Infiniti Oem Paddle Shifters INSTOCK!
If you have worn, scratched, or broken paddles this is a great way to make your car look and feel new again. Infiniti OEM Paddle Shifters fit - 07-08 G35 Sedan, 08+ G37 & Q60 Coupe, 09+ G37 Sedan CV36
_______________________________
This is an OEM paddle shifter upgrade kit for the G35/G37.
(please note that some models do not come pre wired or do not have the mounting brackets on the metal column for the switches, there is no way for us to tell simply by looking up your vehicle even with the vin number if your car can accept this kit.
PLEASE CHECK YOUR CAR PRIOR TO ORDERING TO BE SURE IT WILL ACCEPT THE PADDLE KIT, WE ARE NOT RESPONSIBLE if your car is not pre-configured for this kit).
Fits ALL INFINITI G35 sedan 07-08 and ALL INFINITI G37 sedan 09-up
Does your kit come with everything needed, including all screws for the trim peices? I'm a tad OCD and if I get to a point where someone says not to worry about putting in a screw because of one reason or another, I'm going to drive to Lowes and buy the proper screw. I'd like to avoid doing that
